finishing.com logo ips1
HOME FAQs BOOKS JOBS: Help Wanted Suggestions      you are here: Hotline/Forum => Letter 18039
Stainless steel chemical engraving method
Please advise me how to engrave stainless steel with chemical solutions in room temperature, because I do not have a heat source. Thank you very much for helping me.
ADRY ELSHAZLY
Miroierie Moderne - Alexandria, Egypt
Please give me advice to engrave a sheets of stainless steel with a thickness of (0.7 mm) and 60*40 cm, with a deep of about (0.2 mm), I Knew that HC1(35%):300cc/1 + H2SO4 (98%):200cc at room temperature is a good solution to make the stainless engraving , please tell me before I try, and what is the safest way to use this chemical compunds..? Thank you for help
ADRY ELSHAZLY
M.Nuzzolese - Alexandria, Egypt
Dear Mr. Elshazly,
I respond to nearly the same question before but it was abut the steel engraving the same procedure will work [in shaa allah] with stain less steel. So please take the litter No.11561 in your reference.
Raafat Albendary
National Plastics Electroroplating - Cairo, Egypt
Please advise me how to engrave stainless steel with chemical solutions at room temperature, because I do not have a heat source. Thank you very much for helping me
G.Vaibhav
Hitech Eng Works - Kuwait
