HOME FAQs BOOKS JOBS: Help Wanted Suggestions you are here: Hotline/Forum => Letter 18035
Information on Woods Bath for Nickel Plating on Stainless Steel
I need to electroplate nickel onto stainless steel. I normally use sulfamate solution or the watts bath for my plating on mild steel and other materials. However I believe what is to be used is something called a "woods bath" for plating on stainless steel. Does anyone have any information on the woods bath, its properties, constituents nad working etc?
Sumeet Mehta- Bombay, Maharashtra, India
The Wood's Nickel Strike is a mixure of nickel chloride and hydrochloric acid developed by Donald Wood to strike stainless steel and passive nickel. It may be used cathodically at moderate to high current density, and is sometimes preceeded by reverse current activation in the same bath. The formulation and operating conditions are in the Metal Finishing Guidebook.
Woods nickel is 100g/l nickel chloride with hydrochloric acid added to give a pH of 1-1.5. It operates at 4-8A/dm2 and room temperature. Normal plating time is 1-3 minutes. The process is quite inefficient, but gives a good adherent layer of nickel.
Trevor Crichton R&D practical scientist The Pheasantries - Chesham, U.K. |
