HOME FAQs BOOKS JOBS: Help Wanted Suggestions you are here: Hotline/Forum => Letter 18029
Problems in White Phenyl Manufacturing
Q. I am a manufacturer of white phenyl but I am getting some problems. Some oils gets deposited on top. Slowly the color fades out. Can anyone please give some hint as what could be the reasons.
Rajeshwari- Mysore, Karnataka, India
++++A. It's a normal problem in manufacturing in white phenyl; it's not a matter of worry. Please mix the water and concentrate very slowly , for example, if you are mixing one liter concentrate with 10 liter water then take one liter concentrate and add a few water then mix the concentrate very slowly again add few water and mix it properly then slowly add a little water then again mix the concentrate u will a get thick white colour concentrate and then add water again this is the procedure.
Prithwi Raj Biswas
- Delhi, India
February 13, 2008A. The response to the following query from Rajeshwari, Mysore:
Girish Pargaonkar
You can add some amount of gum acacia and stir well during manufacturing of this phenyl emulsion. The deposition of oil on the top will be be emulsified into the aqueous phenyl.
- Nashik, Maharashtra, India
December 11, 2008A. Dear Sir
KN Chandrasekhar
Reference Ms Rajeswari, Mysore, problem of oil separation.
Many white phenyl manufacturers use various perfumery oils
for this purpose, in most cases these oils are not emulsified properly to mix homogeneously in to the solution
as such the oil separation.
- Bangalore, India
How to make white phenyl more dark? though I am mixing more amount of cutting oil in less water the phenyl is not getting darker. So any of u suggest me how to make white phenyl darker.
Srinivaschemicals - Hyderabad, Andhrapradesh, India
Q. Dear sir ,
I make White phenyl but after adding perfume, I get smell of cutting oil.
what to add to avoid that smell.
- NAGPUR, India
+++++++A. Do add pine oil 1 liter maximum in 200 liters of phenyl there won't be a smell of cutting oil surely ..
Pramod sethi
regards
- New Delhi, India
Dear Sir,
If you can help me at what percentage of chemical should use to make 1 liter of white concentrated phenyl.
Thanks & Regards.
- Delhi, India
February 27, 2008
Dear Sir,
please tell how to prepare the white phenyl and the chemicals used in preparation. As there is a preparation test for the B.Ed student.
With Best Wishes
- Hyderabad, India
May 28, 2008
I am a manufacturer of white phenyl but I am getting some problems, when I add water in concentrate some oil gets deposit on top, slowly the colour fades out, phenyl is not getting darker, I am mixing 1 liter TRO (turkey red oil)and 3 liter pine oil, please suggest.
Raju Upadhyay- Lucknow, India
September 17, 2008
Problems in white phenyl manufacturing: please let me understand what is gum agasia [ed. note: acacia?].
Kaushik Davehobbyist - Ahmedabad, Gujarat, India
October 5, 2008
White phenyl Compound:
Its a raw material for preparation of white phenyl. You can add 1 liter phenyl compound with 10/15 liters of water mixture.
- Vijayawada, Andhra Pradesh, India
January 17, 2009
take 500 gram of castor oil, 500 grams of pine oil of 32% and mix both in a steel vessel, heat it with steam till till it gets very hot, take 10 grams of caustic and dissolve it in 100 ml water, pour the caustic solution in the mixture of castor/pine. heat it through steam until it turns dark brown and starts to become thick. then let it cool down. then add 200 grams of cutting oil and 100 grams of detol. the compound is ready.
najamuddin.hathiyari- rajkot, India
April 17, 2009
I am manufacturing white phenyl with out any mixer and packing in plastic bags (1 liter), after weeks storing became water like water or less white, pl. guide me how to overcome the problem.
manufacturer - Pune, Maharashtra, India
September 2, 20091.First you test your water on water p.H. meter
satya prakash tripathy
2.Your water should be 80-170 in pH (It is Hardness test)
3.If your water is hard you use PGN in Pine oil
4.1 liter 40 ml PGN
5.PGN works for softening the water, and create Hardness white phenyl.
6.lastly I recommend please follow the formula a professional way
with regards,
- Angul,orissa, India
December 1, 2009
plz tell me how to make a phenyl? I am looking to start a small business at home please help me with details or just give a contact no. of a person to contact for the same.
lalit kansalrajdeep - pune,maharashtra,India
Hi, Lalit. There have already been a good number of responses. Please try your best to cast your question in terms of what has already been said, so that the page doesn't just run in circles :-)
Sorry but this page is for public technical discussions; for a number of reasons we cannot connect people commercially except to the site's supporting advertisers. Good luck.
finishing.com
Brick, New Jersey
January 23, 2010
it is indication of excess pine oil
take proper measured t.r.o 1 part and 3 part of pine oil. shake it uniformly for 5 minutes, the mixture must be in proper ratio,
Wait for 3 days, you will get good result, recently I heard there is one time introduced, if you have details, give full details
yellow oil on white phenyl - shimoga karnataka, India
March 16, 2010
The Concentrated should be made with TRO not with cutting oil.The concentration of TRO and Pine/TOP should be clear.
Viral Gandhihome products - Mumbai, India
May 12, 2010
1. I am heating the castor oil 150 grams & pine oil 150 grams.
2.next I mix caustic solution.
3.cooled solution I am mixing cutting oil 200 grams.
problem: separating the cutting oil.
- vijayawada, India
August 11, 2010
Which type or grade of cutting oil can I use for the white phenyl?
Bharat lalwanibuyer - Rajkot, Gujrat , India
November 20, 2010
What should be the proper dilution ration of pine concentrate with water for maximum dilution ? And should I use emulsifier also along with TRO?
Amol Suryawanshiindustrialist - Ahmedabad, Gujrat, India
January 9, 2011
How to manufacture a white phenyl without cutting oil?
madhusudan tirumalasettyManufacturer - pulivendla,Kadpa Dt,A.P St,India
September 23, 2011
I am currently doing trials for White Phynyl. I have tried with ready made concentrate in which we need to just add Pine Oil available in the market. But there are not up to the mark. So now I am trying to start full in house . If any one can guide, it will be helpful.
Apurva Khandelwal- Kolkata
October 10, 2011
We are a manufacturer of TRO. While preparing white phenyl confirm purity of TRO: it should be 70% & its pH should be neutral. Take 3 parts pine & 1 part TRO till you get clear transparent brown colour liquid. Take 9 ltr water charge 1 ltr of this conc mix to get 10 lit white phenyl. There will not be any problem of oil separation and fading of colour.
- Thane, Maharashtra, India
December 2, 2011
Dear Sir, I am planning to start business of White Phenyl. Can anyone help me to advise what all chemicals are to be used and in which ratio as well as the procedure to make the concentrate.
regards,
- New Delhi, India
December 2, 2011
Hi, Rohit.
Please try your best to study the preceding answers and then cast your questions in terms of what has already been said. It makes no sense for someone to ask a question, have it answered, and then for people to start all over and ask the same question again :-)
finishing.com
Brick, New Jersey
December 21, 2011
is there any possibility that we make Phenyl without using cutting oil?
bharat b- bhuj, gujarat and india
December 21, 2011
Kindly inform if you have testing facilities for checking quality of White Phenyl , Liquid Soap, Toilet / Marble cleaners. In case you don't have arrangements can you pl suggest someone who has.
Thanks & best regards
R.K.Sood
- Kolkata, India.
Readers: This site is made available for camaraderie & technical info exchange by our supporting advertisers, and they will contact the inquirer privately regarding their commercial needs. Please offer comments on any technical issues, but not sourcing suggestions or testimonials. Thanks!
