Letter 18011
Flash copper undercoat prior to hard
chroming
Hi! I would like to know whether an undercoat of copper plating
from a rochelle salt bath(15-25 microns) on plastic inj. molds and
dies(working surfaces) with subsequent diamond lapping and finally
hard chroming the molds would tolerate injection molding conditions.
The reason I'm trying this is to "fill up" surface defects but at the
same time have to adhere to mold profile parameters.
Solomon Mordecai
- INDIA
Personally I don't think it's a good idea. Good adhesion onto
copper is possible, but it is more problematic than adhesion on
steel. Plus, depending on the chrome thickness you might have an
eggshell effect.
finishing.com
Brick, New Jersey
Thanks Ted!! Just wanted to know .. whats an "eggshell effect"? as
in peeling due to the shearing forces? I planned this out for faster
turnarounds for molds and dies reducing process timings.
Solomon Mordecai
- INDIA
Picture the shell on an egg; it is rather hard. But its hardness
is of limited value because the egg is soft. Attempts to put the
shell's hardness to use--using an egg as a hammer, for example--tend
to be unsuccessful. A thin plating of chrome on a soft substrate may
be of similarly limited value.
Ted Mooney
finishing.com
Brick, New Jersey |
Molds and dies are usually made of alloyed Cr-Ni steel so the
surface has to be activated to get good adhesion of any plating. This
is better assured using acidic nickel formulas like Wood´s
strike. Then we recomend to plate w/ more nickel (from sulfamate or
all sulfate w/conforming anodes)instead of Cu since it will also
polish very fast and is harder so it avoids what Ted calls eggshell.
Copper will only be good for small very deep pitts or scratches when
a large area of the chrome will not be backed by it. I personally
think of it as a sheet of glass on a bed. Can't lay on it.
Guillermo Marrufo
Monterrey, NL, Mexico
Dear Reader, please --
- Post a
question on a different subject.
- Answer or follow-up on this subject (in non-commercial
fashion).
