Letter 18003
The Effects of Magnetic Particles on Alloy Steel Fatigue Test Pieces [California]
Can Magnetic Particles have an effect on the fatigue properties of alloy steel? Our fatigue tests prior to Magnetic Particle are 200,000 cycles. After Magnetic Particle and alkaline clean/degrease the fatigue drops to about 80,000 cycles. We looked under a black light and there are still some residual mag particles on the surface of the test pieces. I guess the obvious question is to clean it completely and then re-test. Acetone [link is to product info at Rockler] seems to remove all of the particles but we have not tested samples after such cleaning. What is a good cleaning method for removing mag oil and particles prior to plating?
Don Huffman
- Torrance, CA, USA
Dear Reader: please choose what you want to do.
I want to post a question or inquiry of my own.
I want to answer or follow-up on this question publicly (in non-commercial fashion).
I am a supporting advertiser and want to reach the inquirer privately.
