finishing.com logo ips1
HOME FAQs BOOKS JOBS: Help Wanted Suggestions      you are here: Hotline/Forum => Letter 17976
Cleansing pennies...INTERNET IS WRONG I AM RIGHT!
Ok, so I did this science experiment on which liquid cleanses pennies most efficiently, and when I did my research, all of the places I went to said that acids cleanse the pennies better, but when I did the experiment, glass-cleaner with ammonia worked the best, and ammonia is a BASE! So did my experiment go wrong, or am I right and everyone else is wrong? (I wish!)
Melissa
- Port Orange, Florida
First of three simultaneous responses -- ++
Copper, especially copper salts, react with ammonia solution to form a very deep blue cuprammonium salt complex. Hence I am not surprised you got a reaction; however, I am surprised it was faster than acids. I suppose you learn something every day and you have now seen the wonders of science and the importance of not believing everything you are told. Good luck and keep on experimenting.
R&D practical scientist The Pheasantries - Chesham, U.K.
Second of three simultaneous responses -- ++
I tried ammonia to see for myself, and I found it completely ineffective, Melissa. But part of the problem with this question is what do we mean by 'cleansing'? Most students mean 'removing tarnish', the brown color on pennies. But if you mean 'removing dirt, oil & grease, and fingerprints', then you are right. Ammonia is a good cleanser, it just didn't seem to me to be a good copper tarnish remover.
finishing.com
Brick, New Jersey
Third of three simultaneous responses -- ++
I'm doing a project on cleaning pennies. I know for a fact that vinegar and salt can clean pennies.
Shewnsey [last name deleted for privacy by Editor]
- Chicago, Illinois, United States
I recently conducted an experiment and found ammonia to clean pennies much more effective than vinegar. Can anyone explain the chemical reaction of copper oxide and ammonia? (CuO + NH3, I think?) and why a weak base was more effective? I'm puzzled.
Beau O. [last name deleted for privacy by Editor]
- Austin, Texas
December 29, 2011
The chemical reaction of Copper Oxide and Ammonia (CuO + NH3) can be explained in the equation NH3 + CuO = Cu + N2 + H2O where the Oxygen Molecule (oxide) is stripped from the copper to reform with the Hydrogen in the Ammonia creating Water (H2O) and Nitrogen gas (N2) leaving the Copper (Cu) clean and free of Oxide.
The balanced equation is actually 2 NH3 + 3 CuO = 3 Cu + N2 + 3 H2O where 2 molecules of Ammonia combine with 3 molecules of Copper Oxide. This reaction happens very quickly but lets look at NH3 (100% Ammonia or Anhydrous Ammonia) for a moment. This material is a gas under normal atmospheric conditions and only turns to a liquid state at -27 degrees Fahrenheit or below @ sea level. That's why it makes such a great refrigerant in an enclosed system.
To use it as a cleaner it is combined with Water in a 3% or less solution to stabilize into a liquid (H2O + NH3) under normal atmospheric conditions, leaving trace amounts (1-3%) of the NH3 Ammonia molecules undiluted, which is the common ammonia used for household cleaning. Because it is a highly diluted solution, it will take longer to strip the Oxide off the Copper Penny than a higher concentration of Ammonia will say 25%), but it does work the same.
When I was cleaning antique clocks for a living, we used to use Industrial Ammonia to clean the brass components of clock workings, leaving them gleaming like 24K Gold! As a warning however; Industrial Ammonia in concentrations of 25% or higher are highly toxic, lethal and should be used with extreme caution in a controlled environment. Even spilled concentrations of as little as 3% can reach the rate of 500 ppm (considered health hazardous) at breathing height in open air in a room within 3 minutes.
I hope this takes some of the mystery out of your puzzlement.
David Faragher
- Granada Hills, California, USA
