finishing.com logo ips1
HOME FAQs BOOKS JOBS: Help Wanted Suggestions      you are here: Hotline/Forum => Letter 17078
Sputtering vs. Vapor coating
When metallizing PET Film for Fabrication of solar control window film, Does sputtering have any advantages or superior charteristics versus vapor deposition when using Aluminum as metal?
Michael R. Byrd
- Hobe Sound, FL 33455
By vapor deposition I assume you mean ion vapor deposition, or IVD, a common means of depositing aluminum wherin the aluminum is evaporated. Sputter deposition of aluminum should result in a better coating -- the metal reaches the substrate with greater kinetic energy -- but is generally a much slower process, and therefore more expensive.
treglio portrait Jim Treglio
coatingservicesgroup
Lakeside, California
