HOME FAQs BOOKS JOBS: Help Wanted Suggestions you are here: Hotline/Forum => Letter 16063
Zinc Plated Fasteners vs. Stainless Steel
My company is developing an outdoor product line which is primarily made up of 6063-T5 aluminum extrusions. We decided to switch to all 18-8 stainless steel fasteners for corrosion resistance, but there has been some second guessing as to why we didn't decide to use zinc plated steel fasteners. One reason for the questions is because of the higher cost of the stainless fasteners. In our application, a hex bolt is slid into a channel in the aluminum extrusion, and a the assembly is fastened together with stainless steel brackets. The concern that we have is with the potential for galvanic corrosion due to the fact that we have dissimilar materials in direct contact with each other.
My question is, would zinc plated fasteners be a suitable alternate to the stainless steel fasteners? How would the appearance of the bolts (rust) compare to that of stainless over a period of years in an outdoor environment? How much galvanic corrosion would we see with the zinc plated fasteners as opposed to with the stainless steel?
Thanks for any help you can provide?
Scott Liebert- Milwaukee, WI
You probably know that, were it not for its toxicity, the ideal fastener material is cadmium plated steel. It is so close to aluminum on the galvanic scale that there is no galvanic corrosion, it is corrosion resistant itself, and it has great lubricity. Nonetheless, cadmium is a cumulative poison, should be reserved for only the most critical applications, and even there is being rapidly phased out.
The next best material is aluminum plating or coating, again because the galvanic potential is zero. You can investigate Ivadizing for vapor deposition of aluminum, or AlumiPlate for electroplating of aluminum. I fear that you may find the cost unacceptable though.
I am a bit confused by your reference to stainless steel brackets because these will (theoretically) cause the aluminum to galvanically corrode regardless of the fastener material. And, presumably being larger in surface area than the hardware, they will have a more powerful impact.
All of the above not withstanding, you didn't mention how the aluminum is corrosion proofed, so the question is a bit open. But I have seen stainless fasteners used on architectually anodized aluminum in outdoor exposure without any substantial problems. The zinc plating is not a good idea in my opinion because it will be short lived.
July 30, 2009
my company is producing small gasoline engine, we sell our product to Southeast Asian for the long tail boat, but recently we met a serious corrosion on outside fasteners produced by zinc plating, the material of fasteners is low carbon steel, it is been use for fixing some steel stamping parts and plastic panels I am not sure if there are some galvanic corrosion between fasteners and other dissimilar parts, considering from cost, do we have any other proper choice or solution.
Nick Lu- ChongQing China
July 31, 2009
Hi, Nick. There are many choices for fastener coatings including galvanizing, organic coating, mechanical plating, electroless nickel plating, zinc alloy platings, aluminum Ivadizing, and so on.
But I'm afraid that I don't understand your question, and don't understand the application in a "long tail boat". You need to determine whether there were or weren't galvanic compatability issues (and you haven't told us what other metals are involved), and you have to determine whether the plating was defective in this particular case, or whether zinc plating is a bad specification. Zinc plating is rarely sufficient for exposed outdoor use, and ceetainly not in a marine environment.
No other corrosion resistant coating will be as inexpensive as zinc plating though.
