finishing.com logo ips1
HOME FAQs BOOKS JOBS: Help Wanted Suggestions      you are here: Hotline/Forum => Letter 16057
Neutralizing agent
Sir,
We intend to manufacture Mild Steel Wires from wire rods and are interested to find out what neutralizing agent should be used after pickling the wire rod in Sulphuric Acid & rinsing with water.
Your answer will be highly appreciated.
Tarun Khandelwal
- Nashik, Maharastra, India
A silicated alkaline cleaner should be good.
finishing.com
Brick, New Jersey
It depends what you want to do with the wire after neutralising it. If it is not to be plated then the above remedy will offer you temporary corrosion protection only.
khozema Khozema Vahanwala
Saify Ind
Bangalore, Karnataka, India
