HOME FAQs BOOKS JOBS: Help Wanted Suggestions you are here: Hotline/Forum => Letter 16047
Avoiding blue sealing blooms
How can I avoid blue sealing blooms after black anodizing and hot sealing , and if I can't avoid how can I remove it without buffing?
Nilay Gholkar- Mumbai, INDIA
A well maintained Nickel Acetate (mid-temp) bath should give satisfactory sealing without the seal smut. Sealing dyed parts in boiling water without any additives is not the way to go, as most dyes will leach out a little bit into your seal bath, thereby contaminating your seal.
Marc Green anodizer - Boise, Idaho |
Hello Nilay,
You need to try to keep a close eye on your dye and nickel seal temp and PH. it is a must. Also you may be keeping you seals to long. Hot water seal change every day or so. Nickel seal, a week or so depending on your work volume. Check with your suppiler.
Dwayne Conley- Dayton, Ohio
