finishing.com logo ips1
HOME FAQs BOOKS JOBS: Help Wanted Suggestions      you are here: Hotline/Forum => Letter 16039
Plating aluminium tubing to allow soldering
Dear sir,
We want to solder aluminium (heat exchangers), but we can't. According to experts, we must electroplate it first with copper. We try to plating it with copper but not success, please explain the process, and also what is the pre treatment for the aluminium (zincate ? = zinc sulphate?).
Hartono Hadiprojo
steel - Cilegon, Babten, Indonesia
Yes, you need to zincate the aluminum before you cyanide copper plate it. In fact, you should "double zincate" it (zincate it, strip the zincate in nitric acid, zincate it again). But zincate is not zinc sulphate, it is zinc dissolved in caustic soda and stabilizers. You should either buy a proprietary zincate or research the subject via a compterized lit search. Good luck.
finishing.com
Brick, New Jersey
