Letter 16006
Dissimilar Materials
I deal with Alodine 1200s and my question is: Is it safe to
Alodine aluminum parts which have dissimilar materials installed in
them such as steel helicoils, bushings, dowel pins, etc.?
Thank You,
Mark S Draper
- Central Point, OR
First of two simultaneous responses -- ++
I've never had any problem with chromating parts with pins,
helicoils, ect.. although.. they have always been stainless inserts.
Marc Green
anodizer - Boise, Idaho
Second of two simultaneous responses -- ++
We have alodined parts with hardware installed. Have found that we
must use stainless steel hardware because the acid cleaner and
chromate solutions will attack and discolor zinc or cad plated
hardware. Also must give the parts a good final rinse and blow dry
the areas around the hardware to prevent any bleedout of entrapped
solution.
Lee Blanton
- Denton, Texas
To my knowledge, racking of dissimilar alloys when anodizing is
not advisable. I have not heard of the same for alodining.
Dado Macapagal
- Toronto, Ont
Dear Reader, please --
- Post a
question on a different subject.
- Answer or follow-up on this subject (in non-commercial
fashion).
