Letter 15867
Cleaning Pennies
We have lots of pennies but they are really dirty. Do u know any
solution from around the house that could help me clean them?
Ashley [minor's last name deleted by editor]
- Hamilton, Ontario, Canada
Ashley:
If you are collecting coins, you should not use any chemicals at
all - they do a good job, but an experienced collector can recognize
an unnatural finish - the coins will be worth more if you leave them
alone.
If you want them clean for some other reason, any copper cleaner
should do the job - found in hardware stores, WalMarts, etc (wear
rubber protective gloves [link is to product info at Amazon], use
in ventilated area).
Kevin McHugh
- Orland Park, Illinois
April 18, 2008
Hey I am doing a science project on what is the best way to clean
pennies.. I tried vinegar but that didn't work. What should I use
now? Do you think this is a good experiment? Or is it quite boring?
Teryne B [minor's last name deleted by editor]
student - Nashville
April , 2008
Hi, Teryne. Vinegar plus salt will work instantly. So will lemon
juice & salt, ketchup, taco sauce, etc.
But the purpose of your science project is not to learn how to
clean pennies, it is to learn how to conduct an experiment properly.
Our FAQ on Cleaning Pennies
should be exactly what you need. Good luck.
finishing.com
Brick, New Jersey
April 14, 2009
Hi,
I am doing a Science Project for my 5th grade class on "Cleaning
Pennies".
My questions are why does is take so many days to get the tarnish off
of the pennies? If I mix different acids or whiteners together for
example toothpaste, taco sauce and salt will that do the trick of
cleaning them quicker? Is it safe to use all the ingredients
together?
Thank you for your help.
Jake W [minor's last name deleted by editor]
Student - Ludlow, Massachusetts
April 16, 2009
Hi, Jake. You imply that it took many days for taco sauce to get
the tarnish off of pennies. Just how much time did it take?
I don't foresee your head exploding if you brush your teeth after
having tacos for dinner. But I guess you should get your little
brother to try it before you brush your own. Assuming he doesn't
explode or pass out, you can safely mix them.
But think about what conclusion you will have if the mix works
better than the individual ingredients, and what you will have
learned that is of any value.
Ted Mooney
finishing.com
Brick, New Jersey |
