Letter 15089
You haven't given many details abou the solution; - is it acid or alkaline? Furthermore, tin will not deposit onto an anode, so you will not get growths. However, you may be getting uneven dissolaution of the tin from the anode, causing a roughness of the anode. This could cause the "growth" appearance you see. What is the purity of the tin anode? If it is impure, you may be getting insoluble bits left on the anode that ultimately fall off when all the good tin has dissolved. If it is an alkaline tin are you sure the anode has got a film on it to prevent the the stannite/stannate problem. If this is out of balance, you may well get a rough deposit on the cathode. Please give futher details of your system.
Trevor Crichton |
Save
This Page (why?) - Home - ©1995-2009 finishing.com
