finishing.com logo ips1
HOME FAQs BOOKS JOBS: Help Wanted Suggestions      you are here: Hotline/Forum => Letter 15086
Worn Silverplated Flatware
I have several pieces of silverplated flatware that I had been using as everyday utensils until I noticed how a considerable amount of the silver has worn off to expose a goldish and/or grayish metal. I am concerned about the safety of using this flatware now, especially since I have a four and seven-year-old. Thank you.
Shannon Bush
- San Antonio, Texas
It's certainly appropriate to have them replated by a plating shop. Shannon, but I wouldn't worry about the hazards of eating off of this; there is no lead or mercury or cadmium or anything like that in flatware.
finishing.com
Brick, New Jersey
What you're probably seeing is the underlying nickel plate layer, or if your set is old enough, the actual base metal, showing through. At any rate, the only fix is to have them replated by a professional. Check with the manufacturer (if they still exist). If it's Oneida, they should repair/replace them for no or moderate charge.
George Brackett III
- Utica, New York
March 15, 2010
I would like you to advice me if I can feed my daughter in a silver plate, will it be harmful or not.You can give me the advantage and disadvantage for eating in the silver plate.
Jennifer George
Interior Designer - Chennai, Tamil Nadu, India
March 16, 2010
Hi, Jennifer. Silver has been the standard for flatware and serving plates for centuries. It's hard to imagine anything less harmful. Good luck.
finishing.com
Brick, New Jersey
