HOME FAQs BOOKS JOBS: Help Wanted Suggestions you are here: Hotline/Forum => Letter 15030
Hard anodize with big thickness
We are working with hard anodize of aluminium with standard sulphuric acid solution and cannot reach a thickness more that 75-80 micron. Please let me know if there is a possibility to reach a thickness of 150 micron and more with this process or do we need something else.
Thanks in advance.
Lisakov Ian- Israel
Yes..it is possible (but unusual) to get 150 microns (.006") depending on the alloy, your use of proper racking techniques, and processing parameters.
The Surface Treatment and Finishing of Aluminium and Its Alloys |
I think in inches so 0.000 040 X 80 = 0.0032 inches thick. If that is right, then YES, let us now know the alloy and we will come back to you with more data.
Robert H Probert Robert H Probert Technical Services Garner, North Carolina
Am I incorrect? I believe approx. 25.4 microns = 1 mil (.001")?
Marc Green anodizer - Boise, Idaho |
You're both right. 25.4 microns to the mil, so divide the microns by 25.4 to get mils, or multiply the microns by .000 040 to get inches.
But Ted,
By my calculations..he is wanting almost a 6 mil coating, yet by Roberts figures...the coating is 3.2 mil...unless Robert was looking at coating growth on top of the substrate?
Exactly. The coating he is getting is 75-80 microns, equals 3.2 mil. The coating he'd like to get is 150 microns, equals 6 mil.
We anodize at 0°C in a 10% H2SO4 electrolyte and can achieve that kind of thickness, temperature is critical because if the part gets too hot due to a high current density you will burn the part.
Guillermo Luna - Mexico City, Mexico |
Max thickness of hardcoat is limited primarily by the alloy. Since the coating is an electrical insulator, the better the structure (tighter, denser, etc.) the better it insulates and the lower the maximum thickness obtainable will be. On 6xxx alloys, getting anything over 75 microns (roughly 3 mils) is nearly impossible. On 7xxx alloys on the other hand, getting 150 microns is possible. Ramping is critical ( how fast the maximum current density is achieved ). Others may argue that modified power, either superimposed AC over DC or pulse rectification will have a benefit. That would be up to the suppliers of the specific process you employ.
Good luck and let me know how you make out.
For your information, there is an International Hard Anodizing Association (www.ihanodizing.com)that has technical symposiums every 2 years. Attending something like this might establish the network you need to tackle hardcoat concerns.
Milt Stevenson, Jr. Anoplate Corp Syracuse, New York |
