finishing.com logo ips1
HOME FAQs BOOKS JOBS: Help Wanted Suggestions      you are here: Hotline/Forum => Letter 15011
Swedish Standard, SA 2.5 minimum
I need to know the technical details about the following- Surface preparation - Mild steel part the surface needs to be prepared by sand blasting as per Swedish Standard , SA 2.5 minimum or better as per Swedish Standard , If it is possible then please inform about the surface finish value ( Ra, Rmax eg.) which can be achieved by the above mentioned process.
Please respond as early as possible.
Best Regards,
T.N.C. RANGANATHAM
SRIHARIKOTA, A.P., INDIA
September 3, 2009
Hi, T.N.C.. This is a Swedish Institute for Standards designation for "near white" blasted finish -- approximately equivalent to NACE No. 2/SSPC-SP10 [link is to spec at TechStreet], and ISO 8501-1 [link is to spec at TechStreet] WA.2.5
I believe it's actually "Sa.2.5", but I don't know is "Sa" is an abbreviation or acronym in Swedish. I also believe that it is a visual standard, rather than something you measure with a profilometer.
Please see letter 12526 for a more complete explanation. Good luck.
finishing.com
Brick, New Jersey
