finishing.com logo ips1
HOME FAQs BOOKS JOBS: Help Wanted Suggestions      you are here: Hotline/Forum => Letter 15006
Why does gold plating tarnish?
Q. I have observed that the gold plating has some darkening areas over the nickel plated copper base material.
What causes this effect? We all know that gold is a very inert metal & does not corrode or rust. In this case, it should not tarnish. Under what circumstances or condition does this problem arises?
Your advice is greatly appreciated.
Maung San Zaw
A. Hi,
Gold as such will not tarnish. It is inert. The tarnish-like appearance is due to underlying surface getting corroded or oxidized. If the thickness of gold is not adequate and if the coating is porous, the corrosion taking place in the underlying surface may seem like tarnish. Ensure that you have adequate thickness build up of gold, to put an end to your problem.
Good luck ...
Karthik
Goldie book
Gold Plating Technology
Reid & Goldie
A. Hi,
If you have nickel plating as a finish to plate gold onto it will normally not tarnish even if you only deposit 0,1 micron of gold. This could mean that the gold plating solution has contamination, which tarnished. If you have nickel-free plating and plate gold onto copper or bronze the tarnish would come from the base if the gold plating is too thin to form a uniform layer without pores.
Good luck and all the best,
Trudy Kastner
  electroplating service
Durban, KZN, South Africa
Q. Need to know about colouring gold (pink, green, red etc.) Would anyone mind answering this? Need information about the process of colouring gold.
Thank You,
Jayalakshmi. S.
A. Hi, Jayalakshmi. In general, gold is not colored after casting or after plating. Rather, coloring is done by alloying other metals into the plating. You will find some general introductory info about this subject in the Metal Finishing Guidebook. But at this point you may find the subject to be within the domain of art rather than science, with the exact formulas closely held. Unfortunately I know of no articles in the literature exactly quantifying the coloration as a function of the alloying, but if any other reader does, we'd appreciate if they came forward with such references. Good luck.
finishing.com
Brick, New Jersey
Goldie book
Reid & Goldie
Why does pink gold plating tarnish? Now I have a problem about plating. Silver ring plated with pink gold. It is beautiful. but when I show it only 2 weeks, it is tarnishing. I think that because of my sweat or pink gold plating process or chemical of pink gold plating.
Please! anyone help me solve this problem.
Jane
Samuthprakran - Thailand
July 29, 2008
Hi
I have the same problem listed above. My rose gold plating tarnishes very quickly and in some polluted urban areas it tarnishes a green and black color. Does anyone know why my gold plate would tarnish green and black? Its terrible!
Perhaps the solution does not have enough gold in it --too much copper alloy?
How can I check the solution that my plater uses?
Thanks for the input.
Vanessa
California
vanessa zeena
Artisté - California
July 1, 2009
Q. Can anyone tell me if pure gold (such as a necklace) tarnishes in a swimming pool water that has chlorine?
Minou Sadeghi
- San Diego, California
July 6, 2009
A. Hi, Minou. 24 karat gold will nor tarnish, but jewelry is usually made of a lower karat which contains copper or nickel or silver or other metals, and a lot of gold jewelry will tarnish in chlorine. However, the tarnish layer is probably thin and a jeweler can probably restore the shine with some polishing. But don't wear gold jewelry into a swimming pool.
finishing.com
Brick, New Jersey
January 14, 2011
Gold plating has only little effect on nickel materials, but it's best on gold, silver, and copper. Heavy plating can be used.
Janice O.
- Philippines
