HOME FAQs BOOKS JOBS: Help Wanted Suggestions you are here: Hotline/Forum => Letter 15000
Titanium tanks for HEEF 25 Hard Chroming?
Q. I have a client who wishes to use a titanium tank for a small to medium size hard chrome plating facility using HEEF 25N. Does any body have any experience with titanium as a tank liner material in this solution, and what grade/alloy of titanium did you use?
Peter RobbieMTS - Australia
April 9, 2010
A. Hi, Peter. Titanium has been used for hard chromium plating tanks (letter 42796 briefly addresses this), and I don't think the non-fluoride catalyst in HEEF-25 would be a problem. Still, we see a lot of periodic reports of titanium react strangely in the plating industry, perhaps due to the many different alloys. I guess I would suggest that end users get a guarantee from their tank supplier, whereas suppliers should acquire some experience from jar-testing welded samples and building small tanks before committing to big ones :-) Sorry that this answer probably isn't much help! But after many years in this industry, I've seen a fair number of spectacular failures of titanium that were never satisfactorily explained, so I can't claim a full understanding of the electrochemistry in plating applications. Good luck! Regards, |
November 30, 2011
Q. What should hard chrome plating tanks be made from?
How many for the complete hard chroming process?
What would be in each of them?
Buyer (looking to start new shop) - Jeddah, Saudi Arabia
December 1, 2011 A. Hi, Abdulla. There are 3 different hard chroming formulations: the Sergeant bath, the fluoride catalyzed bath, and the HEEF bath. Materials of constructions could be different, depending on your choice, but the most common material is hot rolled steel with PVC lining. Also, the fluoride bath cannot be used for etching, so you need a separate etching bath if you go that route. You need cleaning, rinse, etch, rinse, hard chrome, and multiple rinse tanks. Depending on what substrates you intend to chrome plate, you may need others. But equipment is not as important as knowledge. If you cannot retain a consultant or experienced hard chrome plater to guide you, please see if you can get access to a copy of Guffie's book => Regards,
