Letter 14623
Qwicksilver
Electrolytic Silver Cleaning Plate
Are you familiar with Qwicksilver TM ? It is a
self acting electrolytic cleaning plate -- imported from
England -- that I have purchased from Antique shows? I am in
need of some new ones and cannot seem to find them ! Are you
familiar with either a comparable product or.......something
else that cleans silver "like magic"......without rubbing
and for large objects?
PLEASE HELP! Thanks!
Zoraida Fiol-Silva,
M.D.
- Pomona, New Jersey
Hi, Zoraida. You may also wish to
see letter 4785, which
explains the chemistry.
finishing.com
Brick, New Jersey
^--Browse silver cleaning plates on
ebay
Help,
Where can I buy Qwicksilver TM cleaning plate. I used a
friend's and it is terrific. Any help would be greatly appreciated.
Diana Henry Mann
- Baton Rouge, Louisiana
Qwicksilver plates are available by writing QWICKSILVER P. O. Box
2118 Bristol, TN 37621
Ginny Mullendore
- Madison, MS, USA
I have purchased a Qwicksilver Plate and on the instruction it
does not say what kind of sink or container to use when cleaning. We
have a stainless sink and want to know if it would be okay to use it
to clean the silver pieces we have or do we need to use a non
metallic receptacle. It says not to mix other metals with the silver
pieces when cleaning.
Thank You,
Sal Seidita
Hobbyist - Kingston , New York, USA
What type of laundry detergent do you use to activate
this product (in the USA) as we don't have Persil in this
country?
Jean
Walker-Wiley
home owner - Reston, VA, USA
Ed. note: Some say
Washing Soda [link is to product info at Amazon] works
as well.
Does anyone know how I can purchase qwicksilver online or
do I use the TN address here? Thanks!
C. Sue Cooley
Bed and Breakfast - Bethany Beach, DE, USA
Check out this silver cleaning
plate from Amazon . . .
About 7 years ago I called Quicksilver to order more reaction
agent, and the person on the phone told me to use Arm & Hammer
Super Washing Soda [link is to product info at Amazon]. He told
me it's a lot cheaper, and it's basically the same stuff.
It's been working fine for us.
We recently installed a black enamel sink, replacing our stainless
steel one. I am now using a 3 gallon stainless steel lobster pot.
William Olson
- Holland, PA, USA
Qwicksilver is a trademarked and internationally patented product.
You can buy it for delivery worldwide.
Brian Morris
Qwicksilver Inc - Cape Town, South Africa
I purchased a Qwicksilver plate about ten years ago. Today when I
used it, some silver pieces were cleaned effectively. Others were
not. I tried a second time on these items with no better results.
Also, the plate is now very gray/brown in color--not silver. I tried
to clean it as indicated on the envelope slip that the plate is
stored in with no results. What do I do now to restore it and why
were some things not cleaned?
Beatrice L. Wallace
collector - Hemlock, MI, USA
From the description you give your Qwicksilver plate is almost
totally corroded with the residue of old tarnish. Tarnish must be
washed off the plate immediately after cleaning (as the instructions
clearly state) or it will eventually become inert. It is surprising
you were able to clean ANY silver. After ten years perhaps you should
buy another one. Contact Qwicksilver.
Brian Morris
I just used a "Quicksilver" electrolytic plate that I found to
clean some silver and it works quite well with WASHING soda. An
internet search turned up info that the "secret" is the plate is
simple aluminum and one can get the same reaction using ALUMINUM
FOIL, WASHING SODA, and Boiling or Hot water. Much cheaper!
Richard Heppert
- Kingsport, TN, United States
Ed. note: For more about electrolytic cleaning of silver, please see
letters: 16626,
18126,
19396,
19814, and
34314.
This old wives' tale again. Clean with aluminium foil and you'll
strip your silver plating. Sure it produces electrolytic action, so
does salt and a tin can. Electrolytic action needs to be controlled,
which is why the Qwicksilver plate has an international patent.
Brian Morris
Qwicksilver International Inc - Cape Town, South Africa
I came to this site to find out where I could obtain another one
of these plates; I have one and it is fine. For an activator I have
always used Calgon water softener, but Arm & Hammer Washing Soda
is also fine. I have made a note of the supplier in Tennessee and
will follow it up.
Jewell Margaret Clark
Retired - Surrey, B. C., Canada
March 31, 2006
One of course CAN use a commercial cleaning plate IF one can find
one without spending a arm or a leg.
In simple terms here is what is going on. Sulfer likes to bond to
Silver (oxidize/tarnish) and will do so naturally over a period of
time. You CAN polish it away, but you WILL remove some of the silver
in doing so.
Sulfer also likes to bond with Aluminum MORE than it does silver, and
given the chance, will move. So . . . getting a "tarnished" piece of
silver in direct contact with ANY piece of aluminum (plate, pot,
foil) with the catalyst of HOT water and WASHING soda (look for
Arm&Hammer) sets up the proper environment for this
transfer.
Once the item looks clean remove and completely rinse and wipe down
or residue will result.
As the water cools, the reaction will slow and stop, so start with
the hottest. Washing and Baking soda are NOT the same chemically.
Baking will work, but Washing Soda will work Better.
Richard Heppert
December 30, 2006
Is there to anyone's knowledge a Canadian source for Qwicksilver.
Archie Callaby
Collector - Windsor, Ontario, Canada
May 29, 2007
I too love this product. I was able to locate it on-line
at www.iKitchen.com for around $15.00. Type in Jewelry
cleaner in the search field.
Autumn Broadway
- Valley Center, CA
September 2, 2008
I want to market this product on my website as an entire
kit. May I have input from you regarding this. Thank you.
PS: Web site not up and running yet - depending on whether
this is do-able. Thank you.
Karen Olson
Seller - Highland, New York
September 5, 2008
Hi, Karen. In this age of a world economy, we often get a
dozen or more requests per day just from sellers in India
and China to post their sites. So we can't post offers to
sell if you had your site up anyway. But why not list on
eBay or Amazon, where people already are, instead of trying
to draw them to your own site? Good luck.
 Ted Mooney, P.E. finishing.com Brick, New Jersey
Click the pic to see
Museum Silver Cleaning plate at Hammacher Schlemmer . .
Get the Qwicksilver
activator from Hammacher Schlemmer . . .
September 5, 2008
I have had my plate for 20 years or more. I love it!!! I collect
sterling miniatures, and I would never be able to enjoy them without
Qwicksilver!
Regular old baking soda works for me. Find it, buy it, LOVE IT!
Barbie
Barbie Rench
- Racine, WI
September 14, 2008
after a bit of googling, the activation chemical for the
qwicksilver plate is actually "soda ash" available at your
local pool supply store. Common name is "pH UP"
David Bird
- Adelaide, S Aust, Australia
December 17, 2008
Hello, where in South Africa can i buy the plate as well
as the powder. Thanks
Shalandra
Sitharam
HOBBYIST - South Africa
Dear Reader, please --
- Answer or expand on this
question
(your posting
will appear on this page)
- Ask a
new question
(your posting will
start a new page)
- Advise
of broken links
or obsolete
info
(your posting
won't be published, the bad info will be fixed )
