Letter 14095
Nickel Plating Brass
I am attempting to electroless nickel plate low lead content
Brass. The parts are small pins. The electroless nickel is a mid
phos.
I have had some success to date with alkaline cleaning, followed
by acid clean then plating with a small quantity of steel to initiate
plating. The problem is to get good plating adherence to the brass
and to be ductile enough to withstand crimping of the part following
plating. Would better adhesion be acquired with the use of DC current
at the electroless plating to initiate the plating?
Is there a specific process that can help?
Can a woods nickel strike be used prior to electroless nickel and
will this give better adhesion and ductility?
If the brass is nickel plated will a low temperature heattreat of
say 450F improved adherence and ductility.
I Thank you and look forward to your comments.
Robert Sachs
- Ontario, Canada
Mr.Robert Sachs,
To answer part of your question, may I suggest Wood's Nickel
strike followed by Electroless Nickel. I have seen it done on small
diameter brass tubes (0.5mm to 1.0mm) x 10 to 20mm length used in the
manufacture of contact probes. The parts go through some crimping
process on the tubes and may exhibit much better adherence than what
you are actually doing now. Adherence problem does crop up once in a
while, though.
Good Luck!
Cheah Sin Kooi
. - Hong Kong
Robert:
Lead, even in very small amounts, will have a detrimental impact
on the adhesion of the electroless nickel to the brass. A nickel
strike is strongly recommended prior to EN plate. Use of a nickel
strike would also eliminate the need to use current or other methods
to initiate the EN plate. Sulfamate is preferred because it is
usually more ductile and is more compatible with EN baths, but watts
or woods will also work. Also, avoid sulfuric acid and high current
anodic electrocleaning in the pre-plate cycle.
If your pretreatment is adequate and you still experience adhesion
issues during the crimping operation, you may want to try running
your EN bath at a lower pH to maximize the %P in the deposit.
Generally speaking high phosphorous EN deposits are a bit more
ductile than those from mid phos baths (check with your vendor for
specific values).
Hope this helps!
Mike Barnstead
- Waterbury, CT
Dear Reader, please --
- Post a
question on a different subject.
- Answer or follow-up on this subject (in non-commercial
fashion).
