Letter 14067
Piston Tin Plating Problem
Dear Sir,
We have had problems with adhesion of tin to aluminium pistons in
the past plated in an alkaline potassium stanate solution. To
overcome the lack of adhesion we air age for twenty minutes directly
after removal from the plating solution and before rinsing. An
independent study has found that conducting this air aging process
can form crystalline deposits on the surface which are thought
detrimental to the function of the part. I would like to know what
are these deposits likely to be composed of? Are there methods other
than air aging capable of increasing tin plate adhesion to a level
comparable with that achieved by air aging? We use a simple adhesive
tape method to assess adhesion.
Thanks in advance for any assistance you can give
Kind Regards,
Graham Dodd
- Melbourne Victoria Australia
What is your reference for this air aging? I never heard of it. I
would revisit your parameters of tin plating on aluminum for a
permanent fix of the problem.
Thanks for the response Tom. Like many "great" discoveries this
one was made by accident when several pistons were removed from the
plating cell before the final rinse. There is some doubt whether the
practice of air aging will continue as indications are that deposits
on the piston may be detrimental to the end function of the piston.
Graham Dodd
- Melbourne, Australia
Dear Reader, please --
- Post a
question on a different subject.
- Answer or follow-up on this subject (in non-commercial
fashion).
