HOME FAQs BOOKS JOBS: Help Wanted Suggestions you are here: Hotline/Forum => Letter 14034
Blacodizing Process
1.What is blackodizing ? Process in detail ?
2.What are the methods available for blacodizing ? their advantages & disadvantages ?
3.What are the applications of blackodizing ?
Ravindra Kulal- Pune, Maharashtra, India
1.What is blackodizing? Process in detail?
2.What are the methods available for blackodizing? their advantages & disadvantages?
Sasikaran- Tamil Nadu, India
1)What is the standard to be followed for "Blackodizing" Process?
2)Whether any standard specifies about minimum film(layer) thickness of " Blackodizing"?
3)What prevention / care needs to be taken to prevent the rusting of blackodized components?
Naishadh
N.K.Bhattpower transmission products - Vallabh Vidyanagar, Gujarat, India
Hi, Naishadh, if you spell it instead as "Blakodizing", that is a trademark of Luster-On Products of Springfield, Massachusetts, USA. But, sorry, spelled as blacodizing or blackodizing, I've never heard the term except in inquiries from India asking what it is :-)
Mr.....Mooney, If, you don't know the answer, do not answer. There are sites indicating "Blackodizing" as one of the treatment on components to prevent environment effect and better aesthetics. Better you go thro' key search on this word and you will find many sites. Do not criticize and don't be proud on your experience, one should learn new till the end of life.
S |
Hi, cousin Vallabh. You and two other inquirers were waiting for an answer, and I knew that the term is a trademark if one letter is changed, so I wanted to point that out in case that might help any of you. When people are waiting and no one else is helping them, I think it is better to answer as best I can rather than ignore their request. I did not criticize anyone! If you read my reply as criticism, it was certainly not intended; I simply said I could not find it spelled that way in standards, or in a search of the published technical literature. Because all three inquiries were from India, it probably is a term more commonly used there than in the USA. It may mean the same thing as what we usually call 'black oxide' here -- but I can't say with surety.
Please send me the information about the blackodizing process. I want to know the process, its application in the industry.
Thanx.
Mahesh Chandra Dixitstudent - Kanpur, Uttar Pradesh, India
Hello Mahesh, I have come to the opinion that 'blackodizing' and 'blacodizing' are terms sometimes used in India to refer to the same process that we call 'black oxiding' in the USA. See our FAQ at http://www.finishing.com/faqs/blackoxide.html. Good luck.
