Letter 14018
Tom Pullizzi |
Try a mixed acid proprietary deox that will get more zinc out of the surface.
Be sure the anodizing solution dissolved aluminum is under 12 gm/L
Use a 5% Nitric Acid Dip between the anodizing and the seal to remove sulfates, zinc, and dissolved aluminum out of the pores so that the seal will be better.
Seal must be PERFECT - deI, no calcium.
If you can stand the color, the best corrosion resistance you can get is with a potassium dichromate seal.
Take two aspirin and call me in the morning.
Robert H Probert Editor's
note: |
Save
This Page (why?) - Home - ©1995-2009 finishing.com
