HOME FAQs BOOKS JOBS: Help Wanted Suggestions you are here: Hotline/Forum => Letter 13369
Stained stainless in elevator cab
We have recently remodeled some elevator cab interiors for a commercial office building. The walls are textured 304 stainless. Recently we noticed that some sort of liquid has been spilled on the surface of the stainless steel walls. It looks almost like a coffee spill but this stain cannot be removed with water, alcohol or stainless steel cleaner. Down near the bottom of the elevator it looks like this fluid splashed up from the floor and caused numerous light brown circular stain marks like rain drops. The staining cannot be felt. There is no pitting. It almost looks like the tarnish on silverware. I suspect the fluid was some sort of acid. Maybe some sort of cleaning solution ? 1. What do you think caused the stain ? 2. Can the stain be removed? (we cannot mechanically remove the stains without ruining the finish.)
Thanks much.
Jim Boxmeyerelevators - King of Prussia, Pennsylvania
Search this website and you will see many references to staining of stainless steel. How about a wax that is used by the cleaning people in the building? Also search for a single cleaning person who has an unlabeled bottle secreted in their cleaning cart. I have seen several instances of cleaning people, who with the best intentions, have used things like diluted muriatic acid [linked by editor to product info at Amazon] or bleach solutions for cleaning because they believed that this had some great advantage over the government issue stuff.
Or it could just be coffee. I don't want to create a witch hunt, so a training session for everyone in the building that may get at your elevator can save a lot of hassle and false accusations. Stress the importance of using the recommended cleaning materials and none other. Encourage, during the training session, the cleaning personnel to talk about what they think about the finish, and how they would maintain the surface, Send one of your engineers around the cleaning rounds to see what issues are being faced with maintenance of the elevator. A dirty looking elevator is probably one of the first things noticed by a guest, and makes a big impression.
Tom Pullizzi Falls Township, Pennsylvania |
I suspect urine or coffee.
For urine: Try vinegar.
For coffee: Try ammonia solution or E.D.T.D or or biological washing powder (wet, of course!) or go to a local store and buy the type of 'Stain Devils' used to remove coffee stains from clothes.
Note:Alcohol will only remove some types of organic stains. Try acetone [linked by editor to product info at Rockler] (nail varnish remover - the smelly type!)
Best of luck with the elbow grease!
John Tuohy- Ireland
Most stainless finishes like #3 or#4 polish, which can not be repaired when scatches occur, can be buffed without harming the finish. This may augment the most successful chemical method if more is needed. If you tell me more about what the finish is, I'll give more specific advice.
Dr. Michael McGuire- Pittsburgh, Pennsylvania, USA
This could be either urine or coffee it can be removed with either Oxalic Acid [linked by editor to product info at Rockler] or acetone [linked by editor to product info at Rockler]. If the surface is Brush Finish, a fine paper could be rubber in the running direction to remove the marks and restore the finish
Faizan R.metal services - Dubai, U.A.E.
