finishing.com logo ips1
HOME FAQs BOOKS JOBS: Help Wanted Suggestions      you are here: Hotline/Forum => Letter 13088
Copper coating by dipping in copper sulphate
We are making components out of mild steel.We want to coat these components with copper.We've tried dipping them in copper sulfate [linked by editor to product info at Amazon] solution and they are becoming coated but after a few minutes they tarnish. How could I prevent this from happening.
Orion
- South Africa
Hi, Orion. Immersion plating in copper sulphate solution produces an extremely thin coating which stops building as soon as the steel is very thinly coated. Robust copper coating requires electroplating from a cyanide or pyrophosphate plating bath.
I suspect that a dip in sodium benzotriazole could help deter the tarnish. Good luck
finishing.com
Brick, New Jersey
May 4, 2009
I want to use a simple 1/4" thick copper plate as a heat sink for our components. What kind of coating will prevent oxidization and retain the great heat sink capabilities of the copper plate? Thanks!
Ryan Thomas
- SLC, Utah
May 6, 2009
Hi, Ryan. Sodium benzotriazole would be the best shot. Sodium dichromate might work well but is not RoHS compatible.
finishing.com
Brick, New Jersey
