HOME FAQs BOOKS JOBS: Help Wanted Suggestions you are here: Hotline/Forum => Letter 13075
Chrome removal advice
I have a stainless marine shotgun that has chrome plating on the barrel; I want to remove the chrome plating from the stainless and give it a matt finish with my beadblaster: What chemical can I remove the chrome, nickel, and copper without damaging the stainless or the enviroment?
James Griggs- Panama City, Florida
Removing the chrome is the easy part. muriatic acid [linked by editor to product info at Amazon] (HCl) will do the trick in probably a few minutes. The nickel is the toughie. My recommendation is to find a good plater that can strip it and will have all the necessary chemicals and equipment for waste disposal. I don't think it should cost too much.
Dan Brewerchemical process supplier - Gurnee, Illinois
