Letter 13061
Black passivation process
Dear Members,
We are a fibre company. We have an order for army belts. For army
belt buckles we are electroplating zinc for corrosion resistance and
we need to passivate black chromating on the pieces with glossy
finish., so I will be thankful to know black passivating process.
Best regards,
Mohammed Asad
synthetic fibers - Karachi, Pakistan
Black passivations for zinc are normally proprietery processes.
Based on past experience, in an application with a similar amount of
high wear/rubbing, it has been my experience that a paint is
desireable after the passivate. You could also look into nickel
plating with black chromium as a means to get a more wear resistant
black finish.
Gene Packman
Dear Reader, please --
- Post a
question on a different
subject.
- Answer or follow-up on this
subject (in non-commercial
fashion).
