![]() (Cycles thru suppliers) |
Letter 13030
Marc Green |
You won't achieve this in the anodizing process itself; it must be done by polishing, electropolishing, or brite dipping. Brite dipping is the most common approach but it requires a nitric-phosphoric brite dipping solution which is quite intimidating, requiring as it does a 'garage type' ventilation system, double walled type 316L stainless steel tanks, etc.
Save
This Page (why?) - Home - ©1995-2009 finishing.com
