finishing.com logo ips1
HOME FAQs BOOKS JOBS: Help Wanted Suggestions      you are here: Hotline/Forum => Letter 13024
Electroless copper flash on zincate
Tell me about electroless copper. Can it be used as a flash over zincate prior to electrolytic nickel plating on aluminum?
Pete Faxon
- Oxnard, California
Sorry, I've never heard of that.
finishing.com
Brick, New Jersey
Ted,
You may not have heard about it, but will it work? I have no cyanide in my shop and my treatment system is not designed for it.
Peter Faxon
Sorry, I thought that never having heard of it implied that I don't know whether it will work.
But I suspect that it won't if you insist on an opinion :-)
finishing.com
Brick, New Jersey
Nickel Glycolate Strike
There, now in a few weeks, this letter should be picked up by finishing.com search engine, so I can find it when I need it.
Guide B253-87 [link is to spec at TechStreet] (1999)e1 Standard Guide for Preparation of Aluminum Alloys for Electroplating
Copyright 2001 AMERICAN SOCIETY FOR TESTING AND MATERIALS, West Conshohocken, PA. All rights reserved.
1. Scope
1.1 This guide covers cleaning and conditioning treatments used before metal deposition (Section 5), and immersion deposit/strike procedures (Section 6) that enhance the adhesion of metals that are subsequently applied to aluminum products by electrodeposition or by autocatalytic chemical reduction.
1.2 The following immersion deposit/strike procedures are covered:
1.2.1 Zinc immersion with optional copper strike (6.3).
1.2.2 Zinc immersion with neutral nickel strike (6.4).
1.2.3 Zinc immersion with acetate-buffered, nickel glycolate strike (6.5).
1.2.4 Zinc immersion with acid or alkaline electroless nickel strike.
1.2.5 Tin immersion with bronze strike (6.6). etc,etc.
tom portrait
Pete: Your concern seems to be about cyanides. What I don't understand is why do you want to have copper between aluminum and nickel. As Tom stated, there are several ways to prepare aluminum for electronickel plating that don't use cyanide in any form. I would go for a zincate followed by EN, then an acid nickel strike to activate EN, then straight to your conventional electrolytic nickel bath. Let us know about your outcome and good luck.
Guillermo Marrufo
Monterrey, NL, Mexico
