finishing.com logo ips1
HOME FAQs BOOKS JOBS: Help Wanted Suggestions      you are here: Hotline/Forum => Letter 13000
SUS303 is rusting in 2 weeks
We have been machining some SUS 303 parts, which under normal conditions should not rust. But recently we had been seeing some of our parts with some brownish stains which resemble rust, after about 1 to 2 weeks. We are using a CNC with water based coolant for machining. Any reason for the parts to turn out like this?
Padmavathy Subbrayan
- Penang, Malaysia
Mr. Subbrayan:
What you are seeing COULD be rust, but it is probably sulfides and sulfates from the sulfur in the 303. You can tell which it is by testing in a 5% NaOH solution overnight (it probably will take only an hour or two). If the yellow stains go away, it was sulfur caused. If they do not go away, soak the parts in a citric acid based product (contact us if you need this). If the discoloration goes away, it was rust. Let us know if we can help.
Lee Kremer
Stellar Solutions, Inc.
McHenry, Illinois
July 9, 2010
Hi Mr Lee kremer,
You mention that SUS 303 soaked in citric acid based product can remove rust. I would like to know how long do we need to soak?
Dexter
Dexter Ng
July 9, 2010
Dexter,
It depends on the severity of the rust and the temperature of the citric acid bath. As with what Lee said about the NaOH bath removing sulfur, it could be an hour or two to overnight.
Ray Kremer
McHenry, Illinois
