finishing.com logo ips1
HOME FAQs BOOKS JOBS: Help Wanted Suggestions      you are here: Hotline/Forum => Letter 12326
Magnesium Experiment
I am doing an experiment in which I react magnesium ribbon to hydrochloric acid. Can you tell me the process and how this works.
Latoya Grant
- Spring Valley, New York, United States
Magnesium ribbon is just another form of magnesium metal. This reacts with hydrochloric acid (and virtually all other acids) to form the acid salt of magnesium and hydrogen:
Mg + 2HCl = MgCl2 + H2
Hydrogen is a gas and will be seen as bubbles. However, it is also very explosive, so do not have any flames around when you do it, unless you know exactly what you are doing! Magnesium chloride is soluble, so the magnesium ribbon will slowly disappear into solution.
R&D practical scientist The Pheasantries - Chesham, U.K.
Hi,
I was wondering if you could help me, I've got to do my GCSE chemistry coursework on the reaction between hydrochloric acid and magnesium ribbon, but I can't find any Scientific Knowledge to put in the coursework, would you please be able to give me some?
Thank you very much,
Laura
- Lincoln
Hi, yeh the magnesium ribbon reacts with the hydrochloric acid in a redox reaction, where the magnesium is reduced and hydrogen is oxidised as it gains electrons from the magnesium. It becomes MgCl which is soluble in solution so effervescence is seen as it dissolves and hydrogen is released. Background knowledge you should just write about different factors affecting rate like surface area, concentration or temperature depending on which one you are looking at and explain why, for example with temperature talk about the kinetic energy and collision theory.
Hope I've helped xx
Katie S
- UK
January 19, 2010
I think Kate is wrong
oxidation is the Loss of electrons so the magnesium is oxidised and the hydrogen reduced as the hydrogen gains electrons lost from the magnesium.
Anjola Odulaja
- UK
January 19, 2010
Hi, Anjola. You are right, the magnesium is oxidized and the hydrogen is reduced.
finishing.com
Brick, New Jersey
