HOME FAQs BOOKS JOBS: Help Wanted Suggestions you are here: Hotline/Forum => Letter 12090
Zinc nickel on a grey iron substrate ?
Anybody knows if it would be possible to apply a zinc nickel coating in a grey iron component, for instance a brake caliper.
Alfonso Bustos Garcia- Valladolid
The question, I believe, is about the hydrogen overvoltage of the carbon particles in the cast iron. In zinc cyanide and probably alkaline non-cyanide zinc, the overvoltage is low, so hydrogen is reduced on the metal instead of zinc metal.
Practical acid zinc plating solutions solved this problem. So I suppose that an acid zinc-nickel solution would be all right. I don't have a reference for this, so please check in with an answer if you have one.
Falls Township, Pennsylvania |
