Letter 12089
Difference between SnPb 90/10 and
SnPb 60/40
I'm working for the connector industry and someone was asking the
difference between plated SnPb 90/10 and SnPb 60/40 soldertails.
Is there a difference in melting point, solderability, application
or whatever? Can someone help me?
Thanks in advance.
Frank van Meijl
- Hertogenbosch, The Netherlands
60/40 solder is what is known as eutectic composition. Although it
is an alloy of two metals, it solidifies at one temperature as though
it was one metal (strictly speaking, the eutectic is at 61.9 percent
Sn, but 60 percent is the usual industry standard). Solidification
temperature is 183 degrees C.
90/10 is well away from the eutectic. It begins to solidify at 300
degrees C, and the first metal to solidify has composition 97Sn 3Pb.
Solidification then is progressive as the temperature is allowed to
fall, with the last bit of metal to solidify being 65Sn 35Pb at 250
degrees C.
60/40 is the usual electrical solder. Can't help you with
application for 90/10.
Bill Reynolds
consultant metallurgist
Ballarat, Victoria, Australia
I don't know about the solderability, but the melting point of the
90/10 alloy will be higher than 60/40. The eutectic point for
tin/lead is 63/37.
James Totter,
CEF
- Tallahassee, Florida
Both are industry standards and the terminology simply means that
there is 60% by weight tin & 40% by weight lead in 60/40. As said
above, 60/40 will solder - melt, as in when soldering - at a lower
temperature than 90/10. This may be important in assemblies where
higher temperatures will damage some components and will also have
energy saving implications. The 90/10 alloy is often called out to
get that little bit of lead in the deposit. The lead is believed to
halt or slow the formation of tin whiskers.
Megan Pellenz
- Syracuse, NY
90/10 is used in some electronics for its higher melting
temperature than eutectic solder. Using 90/10 inside a component will
allow the component to then be soldered into its next higher assembly
(such as onto a PWB) without the worry of solder joints inside the
component reflowing and creating a defect. Sometimes the reflowing of
solder inside a component may be a worry, other times it is not.
Dave Laidig
- Chandler, Arizona
Thanks Dave. Couldn't think of why anyone would deliberately make
a soldering job more difficult by using 90/10 instead of 60/40, but
your explanation makes one smack one's forehead and mutter about
things that should have been obvious!
Bill Reynolds
Thanks a lot guys for your response on my question. It helped me
to understand the difference between 90/10 and 60/40 solder alloy.
Best regards,
Frank van Meijl
90/10 Sn/Pb solder balls are typically used in high-speed
applications such as BGA packages, pc-board type stuff. I
don't know if that aspect has come out already, but I hoped
it might be helpful.
Have a great day.
Ralph Raiola
Electronic Products Magazine - Garden City, New York
can i simply replace an 80/20 finish with a 90/10 finish.
my concern is that the 80/20 finish is too soft and tend to
be scraped during trim and form. since 90/10 is a bit
harder, it might be able to address the scraping issue.
manny ramos
- Philippines
Electronic Products is free to
qualified professionals
The basic difference you face in 60/40 and 90/10 is the
composition of Sn and Pb by weight. The lowest melting point in the
eutectic is reached at a composition of 63/37. Addition of Sn
increases the hardness of the alloy and so as the melting point.
I have read a paper stating the preference of 90/10 over 60/40 is
the formation of dendrite during aging. When maintained at high
humidity conditions or with some potential difference the dendrite
formation (needle like growth) is more prevalent in 90/10 then 60/40.
These dendrites can grown to extent of short circuiting and causing
failure.
60-40 has the advantages of melting at lower temperature so in
reflow soldering (SMT Components) the whole board along with the
components is brought to the melting point of the solder. Some
manufacturer prefer that the temperature not be raised above 200 '
c,in this case 60/40 is preferable while manufactures who doesn't
mind about high temperatures prefer 90/10 who's melting point is
220-225 'c. If your requirements can match these criteria you can
change from 60-40 to 90-10 or 80-20. Those who don't want to go to
90/10 range but prefer a low temp soldering stick with 80/20.
Good luck...
Karthik
I see in the letter above where the 90/10 SN/PB melting range is
higher than the 60/40 but can anyone give me the melting range of
80/20?
Regina J Huff
electronics - St. Petersburg, Florida, USA
September 15, 2008
Hi,
I have come across slivers in bandolier terminals, which is
an insertion process of plated terminals.
This has the potentiality of causing short circuit between
the adjacent terminals.
Can this slivers be avoided in bandolier process. If yes,
how?
Pradeep Kumar
machine shop employee - Cochin, Kerala, India
September 15, 2008
Hi, Pradeep. I understand what a bandolier plating
process is, but I don't think you've given us quite enough
to go on. I, for one, don't have a good picture of what you
mean, so no idea of how to prevent it :-)
finishing.com
Brick, New Jersey
March 16, 2009
I want to find out which solder (tin/lead) composition
like 60/40, 63/37, 75/25, 80/20, etc. is the brightest,
shiny, lustrous.
G S ARORA
BUYER - DELHI, INDIA
