Bud,
Dilute muriatic (hydrochloric) acid would temporarily give a
shine to the brass deposit, albeit a somewhat "matte" one.
Once you applied it, however, there would be no way of
getting ALL of the muriatic out of the brass pores. You said
it was plated onto a steel base-alloy, therefore, the acid
chlorides would eventually start to leach iron from the
steel base toward the surface. You would end up with a nice
greenish hue on your brass deposit. I would stick with the
vinegar (acetate) solution, followed by hand-buffing.
Randall Fowler
Cleveland, TN, USA
Hi,
I see you are talking about the effect acid has on metal.
I also have a question about this. I'm active in a living
history group and have therefore made a chainmail hauberk
for myself. I used galvanized wire for this purpose. But
after completing the hauberk I realized that galvanized wire
wasn't very authentic. So now I want to use acid to strip
the hauberk of its zinc layer. What kind of acid should I
use to do so and at the same time not damage the wire
itself?
Bertus Brokamp
- Utrecht, the Netherlands
Hydrochloric acid will attack zinc very rapidly and steel
more slowly. If you can obtain "inhibited" hydrochloric
acid, which is designed to lessen the attack on steel, the
results will be better.
finishing.com
Brick, NJ
