HOME FAQs BOOKS JOBS: Help Wanted Suggestions you are here: Hotline/Forum => Letter 12065
Strip off paint on ABS
Dear sir,
I want to strip off paint from automotive ABS part (like rear mirror) for plating on ABS.Would you recommend how to strip off paint with out or little bit attack on plastic.
Best regard,
Prasarn Hutpattanasilp- Samutsakorn, Center, Thailand
Dear sir,
We should know the kind of paint but generally paint removers are two kinds.
1-based on organic solvent[methylene chloride-xylene...etc]
2-based on caustic strong alkaline to destroy the paint film[NaOH-S.phosphate....etc]
So until you telling me the kind of paint you use the second type of removers is more safe.
RAAFAT ALBENDARYN.P.E - CAIRO, Egypt
Dear RAAFAT,
I don't know the type of paint but it is used in automotive industry. The solvent base strip off paint may be too agressive to strip off paint on ABS parts.
Best regards,
Prasarn HutpattanasilpLorYongSeng Co.,ltd. - Samutsakorn, Center, Thailand
Prasarn,
What Raafat said is l00% true ... in fact I didn't even know that there were two types of paint remover. Thanks for the education, Raafat!
He didn't recommend the first one BECAUSE the standard cement for ABS happens to be related to methylene chloride ie. MEK / methyl ethyl ketone [linked by editor to product info at Amazon]. Don't even consider using it! It will dissolve the ABS very nicely, thank you!
| Freeman Newton - White Rock, British Columbia, Canada | Ed. note: Please keep Freeman in your thoughts & prayers. Message from Freeman, Dec. 2010 |
Dear sir,
It is clear that you don't know the type of paint[polymer] so I will ask one expert [friend] till that you can use the alkaline remover [pH>12]. I'm sure paint film will destrued but take care this will make slightly etched ABS so make one sample first to adjust the time
Good luck,
RAAFAT ALBENDARYplastics electroplating - Cairo, Egypt
