finishing.com logo ips1
HOME FAQs BOOKS JOBS: Help Wanted Suggestions      you are here: Hotline/Forum => Letter 12014
Coating stainless steel
We are attempting to use a cyanoacrylate adhesive to bond a stainless steel part to a rubber part. The glue will not adhere to the stainless steel. I would like to know if anyone has a suggestion regarding coating the stainless steel with an aluminum rich coating (ARC) in order to accomplish this.
James Henson
Cooper Tire & Rubber - Bowling Green, Ohio
Try using a glue called Sicomet. I used it succesfully to bond stainless steel to rubber.
Sergio Lievano
- Santa Ana, California
Our company is trying to do the same thing, bond rubber to a 17-7 stainless steel and we're having mixed results. We're using a chemlok 205 primer with a 250 adhesive. We're cleaning with MEK / methyl ethyl ketone [linked by editor to product info at Amazon].
If you find anything else that works well, please pass it along.
Thanks and good luck.
Elmer Lee
- Ann Arbor, Michigan, USA
