Letter 12001
Battery acid corrosion on
swingarm
I had my battery leak acid all over my swingarm (piece of aluminum
that holds the rear wheel in place on my motorcycle) So now the
swingarm is discolored where the acid hit. How would I be able to
remove these blemishes while having the finish match(original finish
is a dull aluminum color)? I need a list of what to use so I can do
this job, what works best and easier.
Thanx,
Antonio Reis
- Union, New Jersey
Toni,
When the battery acid (sulfuric acid solution) leaked on to your
swingarm, it removed an aluminum oxide layer, which provides the
"dull aluminum color" to the part. The only way to bring the surface
metal of said swingarm back to some degree of uniformity is to remove
it from the bike, then remove any bushings/bearings, etc., then have
it stripped and re-anodized at a finishing shop. It's really not that
big of an operation for a facility of this nature. You or your
mechanic would be doing all the knuckle-busting stuff. There is a
company in Union that I know would help you out either through their
services or their recommendations. The internet yellow pages are a
wonderful thing.
Lead Setter's Note: Please visit our
Shops directory, several of our
advertisers specialize in automotive refinishing for the
hobbyist.
Dear Reader, please --
- Post a
question on a different subject.
- Answer or follow-up on this subject (in non-commercial
fashion).
