Letter 11365 Hard anodize for 2024 Al alloy
Can 2024 aluminum alloy material be anodized in Hard anodizing bath (H2SO4 conc. :150 - 175 g/L& Temp:4 to -2 deg C )? What is the suitable current density setting? Please advise.Thank you. Neo Tiang Hua
First of two simultaneous responses -- Hi, Of course, the 2024 alloy can be hard anodized. It is a tad more difficult but you can anodize it nonetheless! You can control your tank: T = -2 deg C to 0 deg C Best of luck, Dr. Hocine Djellab
Second of two simultaneous responses -- Hardcoating 2024 (or any other hi copper alloys) is a problem. My shop does regular anodize & hardcoat anodize. There are many proprietary systems used for hardcoating hi copper alloys. For the last 40 years we used a system called IMPERV-X which hardcoated 2024 & other hi copper alloys no problem. Other people use pulse rectifiers or other so called tricks. We gave up our IMPERV-X system last year & now do not do much hi copper alloy hardcoating. We have a few jobs that are 2024 for hardcoat that require a very thin coating (.0002"-.0004" thick) & those jobs are no problem in our normal hardcoat process, but we can not do full spec thickness (.002"+/-.0004") jobs anymore. David A. Kraft
We do 2024 and normally use 32 ASF.
June 4, 2007 Hard anodize of 2024. Is a coating thickness of 0.003" a bit too
much for 2024 aluminum. Russ Sherman
June 5, 2007 Yes, Russ, that is probably a bit too high to specify unless there is a particular reason. The most conventional thickness would probably be .002". Why was the surface shotpeened? Sometimes this is done to counter fatigue stresses, so it is important for you to know that hard anodizing will destroy that compressive effect, and parts should not be hard anodized if there will be fatigue loading. Please try to express your question in terms of what you are trying to do rather than in the abstract. Thanks.
Dear Reader, please --
Save
