finishing.com logo ips1
HOME FAQs BOOKS JOBS: Help Wanted Suggestions      you are here: Hotline/Forum => Letter 11239
Clear coating aluminum wheels
I have an 83 Porsche 944. The clear coat on the stock "cookie cutter" wheels had deteriorated badly. So I stripped the bare aluminum with MEK / methyl ethyl ketone [linked by editor to product info at Amazon] (not the anodized black paint), wet sanded a bit to clean up some of the factory roughness and buffed them out. Not to a mirror finish, but far better than unstripped. I didn't clearcoat the wheels after finishing and have to periodically clean and buff. Is there an "over-the-counter brand" of clear coat that will give me good, lasting results? And if so, how do I prepare the wheels for spraying?
Jeff Gee
- Simpsonville, South Carolina
February 18, 2011
Hi, Jeff.
Automotive clearcoat is "two component" or "two pack"; the body shop mixes the two components and quickly sprays before the coating catalyzes and hardens. "Single component" over the counter stuff dries rather than catalyzes, and just isn't as durable. If you plan on redoing it regularly it can be okay though. Good luck.
finishing.com
Brick, New Jersey
