Letter 11101
Freeman Newton |
Hello George,
Are you sure that corrosion is the reason that the frames fail? Stress can encourage corrosion, and corrosion can encourage cracking. But if the stress were less then the corrosion may not be a problem. With all the rivet holes you speak of it is likely that damp air can get inside the frame, but then when the frames hot or warm the moisture should be driven out too. You could brush plate zinc on the outside of the frame, as a sacrificial protection, and but aluminium is sacrificial to steel also, so the riveted on aluminium plates should, already, be helping there. The little spaces between the riveted on plates and the frame will be good places for corrosion to take place, try and avoid them or seal them at least. I'm sure you can plate the inside of the frame, using some ingenuity, maybe carbon rods (with spacers) placed inside the steel tubes before joining the tubes (the rods wired together too), then when the frames made pure in electrolyte and power it up. It doesn't sound too practical though, and if your then gonna drill lots of holes in it it does make much sense either.
Really the only thing to do is design it as well as you can, build it as best as you can. Remember not all steel or mild steel is the same, there are variations within grades (from manufacturer to manufacturer). Then if you want it plated (zinc or tin/zinc) take it to a professional. They'll do a better job, and know about the safety issues and deal with some chemicals you don't want to play with (i.e. chromates - plating just aunt the same without 'em). Then paint it as you like, or get a professional to do that too. Then take it home and park it in a nice dry garage.
I hope I've been some help, in a vague and general way.
Ian Brooke
university - Glasgow, Scotland
Hi Freeman,
Just a quick note to say that there has been a great deal of study regarding brazing and welding. Many space frames have been examined after damage. Seldom if ever does a break occur in a brazed joint. Metal seems to rip and pull apart adjacent to the brazed joint or somewhere away from the joint. Folks who know more about this than I claim that the application of brazing material forms an alloy that is much stronger than the brass based alloy applied.
It appears that welding lowers the cost of building the frame and produces higher heats in a more localized area around the weld. It is said that brazing is done with lower temperatures, but this heat travels further down the tubing creating warpage and making it more difficult to produce a truly straight frame. Others suggest that the high heat created by welding makes the metal more porous and more prone to rapid corrosion.
George Breckenridge
- Kent, WA
Hi George,
I was flabbergasted to 'hear' that brazing is stronger than welding (of steel) ... I canna believe it! A brass, copper zinc (or wotever) alloy is STRONGER than steel! I strongly suggest you check with NASCAR!
Ian was right and I was wrong. Aluminum is (slightly) lower on the galvanic table than iron. And what he says about checking out the 'various' steel tubings makes sense. Some will stronger than others (undergoing perhaps more cold drawing) but that means most likely that they have more stresses which could prematurely show up after welding.
Yes, definitely go to NASCAR! Maybe they use ultra high tensile cold rolled/drawn tubing BUT (and I'm guessing) perhaps they use collars (sic. sockets) which one brazes onto. The theory being, perhaps, that the lower brazing temperature will not disturb the lattice structure of the steel as much and, because of the sockets, there is a nice 'length' of a more flexible 'weld',ie. brass (something like copper pipe fittings).
Then there's stress corrosion ... so you must get some good advice on the Quality and the thickness of the tubing you want to use. My suggestion of l/16" Pe washers between the aluminum was to retard/prevent corrosion. The 'washer' could be made of a narrow strip of A thin plastic material taped to the frame. Then you could pop rivet to your heart's content. Use nylon if you wanted to (much, much harder and takes more heat) but HdPe is good to around 150 degr. F continuous.
The advice of keeping the machine in a nice, dry garage makes sense ... especially if you want to keep it for many years.
I sure would like to hear what the metallurgists at NASCAR say ... or contact one of the racing teams and ask them but they'll possibly say Titanium!
Yes, I know it's all about the HP/WEIGHT ratio but I'd rather add a few pounds to play safe.
Freeman Newton |
Hi Freeman,
When I look at an outfit like NASCAR, I try to evaluate their focus. Do they care whether a frame lives longer than it's short life on the track? Probably not. Furthermore, and based on my limited exposure to their cars, they seem to use thicker, heavier, materials, with far fewer elements.
I don't think there's too many people or entities that care how long a structure like a space will live. Even with no protection, they hold up long enough to sell, and then it becomes the owners problem.
I have received a number of good tips, and I appreciate them all.
George Breckenridge
- Seattle, WA
Hello Everyone.
Let me get this disclamer out in front. I am not a plating guru. However I work for a company that has a large plating and wastewater operation. So I Have gotten a bit of a crash course.
As for your spaceframe or any other steel structure in which you want to prevent internal corosion. My personal favorite is expanding foam. But you must use a good dense closed cell foam. The trick is to drill or find a hole in the particular tube you are filling near the end which is a snug fit for your applicator tube. There must be a way to vent the pressure at the other end. Considering your frame has already been poked full of holes and pop rivets. All you would have to do would be drill one out at each end of a tube fill from one end and then plug that hole with a pop rivet. Clean up the mess that comes out of the other end with the appropriate solvent. (do this before it hardens or you will be all day trying to clean it off) Then plug the second hole. Assuming that the metal is in decent shape and the rivets are holding on tight, the foam will expand to the full volume of the tube and force its way out any cracks or into the next tube it if wasn't a but weld.
If you have already checked and the hole space frame is constructed of open welds. Then someone could concievably start filling from the lowest point on the frame with several rivets drilled out and have an assistant run around with a can of solvent and a rivet gun to reseal the holes as the foam climbs past them. But you would have to do it in a fairly short period of time. In other words be sure you have all the foam you will nead before you start filling. My personal favorite is the stuff you find in aerosol cans at wal-mart or hardware stores. It is more expensive by volume but you dont have to worry with mixing it properly and having it harden before you can get it where you nead it.
I use it for sound deadening and rust prevention (and repair) in lower fenders of automobiles. (anyplace that will not need to drain)
Don't ever use in a enclosed area composed of thin material (i.e. sheet metal) that doesn't have enough space or vents for the pressurized foam can escape or else you will end up with a deformed panel.
I personaly have a plymouth fury that was starting to rust in the rear quarters because of a sloppy weld. About ten years ago when a friend who worked at a body shop told me to try the foam. It worked perfectly. More recently I have filled just about any void in the body and frame that can be safely filled with it. (except the doors which of course need to drain) You can only hear the wind noise that comes through the glass. And there is no way for moisture to get in where it can cause corrosion. So far it has only added about 25lbs (around 11.3 kg) to the total weight and has been a major improvement to the vehicle.
How does this relate to plating? I'm not sure but if you are having proplems with internal corrosion in your plating shop it would be worth a try.
Bryan Denton
- Lawrenceburg, KY, USA
Bryan,
That's not a bad idea for George to try out.
My only input is that you should check with the foam supplier about the density. I believe you may find that the foam, normally a Polyurethane, comes in different densities and perhaps a 4 lb density maybe the answer. Your local fibreglass supply house should be able to help you. (4 lb means that once foamed, it will weigh 4 lbs/cu.ft).
The only other thing is due to the very small diameter of the space tubes, may I suggest you get a 'scrap' piece and try to find out how FAR down the foam will travel after being injected through one of the 'holes'. What Bryan said about 'holes' is right on. You may need a number of these to ensure that the foam goes all the way down.
Freeman Newton |
Years ago, Porsche built the spaceframes of at least some of their
917s of tubular aluminum. The state of the aluminum fabrication art
was not so advanced - so cracking was a very real worry.
In order to allow for easy crack detection they would pressurize the
inside of the tubular structure via a simple tire valve fitting - as
long as pressure "held" all was well. Any loss of pressure indicated
a crack - and finding the crack required only soap bubbles! Clever,
yes?
Of course, upon initial construction of the frame, one would provide
for the interconnection of all the tubes using a drilled connection
at welded tube intersections as well as a high level of welding
precision. Any structure that reliably holds pressure can be viewed
in good confidence.
Internal corrosion of such a structure would be easily prevented by
eliminating oxygen & moisture inside the tubes by simply
evacuating the structure using a vacuum pump, (to 500 microns or so,
holding for 30 minutes), and providing a mild positive pressure,(5 -
10 psi - no more), using DRY nitrogen.
No oxygen & no moisture equals no corrosion, EVER!
If one added a pressure gauge permenantly piped into the tubular
structure, you would have an clever & reliable corrosion
prevention & crack detection system. One which weighs nearly
nothing - costs almost nothing - with maximal reliability.
Just a thought....
Dale Andersen
- Charlotte, No. Carolina
Regarding attaching aluminum (or other) panels to tubular
frames:
Wherever practical, one should avoid drilling rivet holes into the
closed tube frame members - no matter how carefully installed, over
time, the rivets will leak and allow ingress of atmosphere &
moisture.
Filling the tubes with structural foam has much to recommend it, the
foam can provide considerable buckling resistance - future frame
repairs requiring welding could be more complicated, however.
Why not avoid the holes for rivets all together? During the
fabrication phase weld on tabs and riveting strips at appropriate
locations. A bit more weight,(and work), in return for "no
worries".
When installing the chassis skins generally, consider using one of
the good STRUCTURAL adhesives to bond the panels to appropriate
chassis tubes.
These adhesives are easily strong enough to absorb considerable
structural loads over wide areas with few point loads.
This practice greatly reduces,(or eliminates), rattles & drafts -
not to mention the stress risers that often lead to cracks between
rivet holes in the skin panels.
Over a surprisingly short time, nearly all riveted structures "loosen
up" and become much less stiff. Structural adhesives could go a long
way towards eliminating this fault; a MUCH improved assembly.
Be forewarned: Aluminum adhesive bonding, (as well as welding), is
much less reliable than with steel for the amateur and professional
alike.
With steel panels, the constructor could forego many additional rivet
tabs & etc. Structural adhesives could STILL be used with well
designed spot welds REPLACING all those silly rivets.
Good rivets, after all, are EXPENSIVE and they do weigh
something..more than you may think!
A full weight analysis would most likely show weight REDUCTION with
this steel panel alternative! Any weight GAIN can be addressed with
detailed design.
In any case, a steel panel alternative will almost certainly result
in a stiffer, stronger & cheaper structure. It will likely have a
much longer service life as well.
STEEL - may not be as "sexy" as aluminum - but very often it is a
better choice for the "home based" craftsman.
With steel instead of aluminum skins, you will lose the ability to
polish it. To get the "polished aluminum" look -check out the various
films used for vehicle wrapping.
Dale Andersen
Save
This Page (why?) - Home - ©1995-2009 finishing.com
