finishing.com logo ips1
HOME FAQs BOOKS JOBS: Help Wanted Suggestions      you are here: Hotline/Forum => Letter 11064
Surface treatment for magnesium
A housing consists of several die-cast magnesium parts. The parts are yellow chromated acc. to DIN50939. The housing comply with EMC requirements. At high humidity and temperature the corrosion protection of the surface treatment is not sufficient anymore. This causes EMC problems. What is a better surface treatment?
Jerry Roctus
Thomson multimedia - Breda, The Netherlands
Have you considered anodizing? This process can be done on magnesium, not just aluminum, and may give you better results.
Tim Neveau
Rochester Hills, Michigan
Another possibility often employed today is electroless nickel plating of the magnesium.
finishing.com
Brick, New Jersey
