Letter 11031
Phosphating and corrosion
resistance
I would to ask some question on Phosphating process. As we know
the phosphating process can improve the corrosion resistance of the
parts. Our company's sub-contractor produced some rust parts with
phosphating. Would you tell me what the paramaters are to make sure
the corrosion resistance of the finished parts. Thank you very much!
Ricky Au
- Hong Kong
Ricky,
Phosphated material alone is not a very good corrosion resistant
finish. It is a very good base for powder coating and then you will
get better corrosion resistant rating. If you want corrosion
resistance there are different chromates on the market that will
definitely be better for corrosion resistance.
Lee Moss
- Calgary, Alberta, Canada
Phosphatization layer gives good protection against corrosion
while being base for oiling or coating. Otherwise protection and self
healing is limited. Beware especially from excess of 'white beard'
which is essentially corrosion. Of course no rust should appear
before oiling/painting
Arik Lin
- Israel
You don't specify what type of phosphate. If it is iron phosphate,
it should have a "sealer", either chrome or non-chrome. If it is iron
phosphate, the parts should be painted or e-coated within 24 hours.
Bill Hemp
tech svc. w/ chemical supplier -
Grand Rapids, Michigan
Dear Reader, please --
- Post a
question on a different
subject.
- Answer or follow-up on this
subject (in non-commercial
fashion).
