finishing.com logo ips1
HOME FAQs BOOKS JOBS: Help Wanted Suggestions      you are here: Hotline/Forum => Letter 11026
Embrittlement of Ni electroform after heating
What mechanism would be responsible for embrittlement of Watt's Ni electroform after heating 230C for 30 minutes? If tramp elements are responsible, what chemical analysis can be done to identify species?
Kristen Gratalo
- Boise, Idaho
If you have brighteners in your bath they are causing the problem. Get the concentration as low as possible to attain the results you require.
Russell Richter
Gar Electroforming Div.
Danbury, Connecticut, USA
I'm not experienced with electroforming, but I wonder why you would use a Wood's bath for this purpose; the sulfamate bath is much better suited, I think.
Michael Brewington
plating shop - Salisbury, Maryland
Usually it is Sulfur that codeposits with the Nickel and when heated can cause the nickel to become brittle. But usually the temperature and time are usually higher to cause this problem. Make a foil from the solution and send it out for sulfur analysis. Also you should make a foil from the Watts solution, brand new, as a reference.
George Shahin
- Rock Hill, South Carolina
Kristen:
Just to name the most common, lead in excess of 0.01%, copper in excess of 0.01% and chromium above 0.003% cause a reduction of ductility to the nickel plate at room or below 260C. I agree with George that sulfur in excess of 0.002% gives annealing problems but it is generally known that it comes from brighteners and begins above 260, not 230C. You're not using sulfur brighteners for electroforming, or are you? Have you checked your boric acid lately? If it falls below 20-25 g/L it can also cause internal stress. Also there are numerous organic materials (electroforming practices unfortunately live with them in the bath) that will be dificult to trace by chemical labs and also affect either at elevated or room temperature. Find a good lab and go back to basics (dummying and activated carbon treating).
Guillermo Marrufo
Monterrey, NL, Mexico
