Letter 11013
+ I need to know if coins corrode more in salt or in fresh water. Is an emergency. I appreciate if you could answer me as fast as you can. Thank you. Andrea V
+ An emergency, Andrea? Is someone choking on a coin and you want to know which kind of water to pour down their throat to dissolve the coin? :-) Seriously, this is a public forum and a good reply may not come until next month, or after you graduate. Sorry! But explain your science project or patiently apply the search engine -- the question is answered many time on this site. Good luck!
How can I find research on coins rust faster in salt
water or fresh water? For my
daughter's project she's in 6th grade. Tina S |
Check the town library (maybe the reference section) for a book on "Corrosion", Tina; the issue of salt water vs. fresh water corrosion will be covered, although maybe at a level beyond her grade. The librarian can help with age-appropriate stuff.
Salt water conducts electricity because it has salt ions dissolved in it that can transport electrical charge. This means that larger galvanic corrosion currents can flow. If a coin is made of two metals, like post-1982 pennies (which are copper plated zinc), the chemical reactions between copper and zinc will go faster.
Also chlorides (salt is sodium chloride) are corrosive. You've probably heard that cars corrode faster in the industrial belt where salt is applied to icy roads. Good luck!
Ted Mooney finishing.com Brick, New Jersey |
My mom and I have been working on a corrosion project. we have the cups set up with salt and coins in them and we have been documenting them for the past 2 weeks. And now the teacher is asking for wbesites on where we are getting my information.. funny thing is I have been doing this experiment with no computer. And now that I need websites that have more information on this we can not find them. I was hoping someone out there would have an insite on some websites that we could look at?? Thanks for anyones help in guiding us to more knowledge.
CHARLES ![]()
6TH GRADER - WPB FL
+++++++ There are dozens of threads on the subject on this site, Charles. We hope they'll help. But what were your results? What "hypothesis" did they support or tend to disprove?. Because the real purpose of this exercise is not to prove that salt water corrodes a coin faster or not, but to get you to practice the methods of conducting an experiment. Now here's the thing. If your results were like mine -- that is, that the salt water did not corrode the coin faster -- yet your research says that salt water is more corrosive, what is your project going to say? Being in sixth grade I don't think you are prepared to explain the science behind that conflict; rather, I think you will say that it is widely reported that salt water is more corrosive than fresh water but your experiment did not demonstrate it. That is an interesting result because you can justifiably say "prove it! -- my results don't support that claim". Good luck!
Mr. Me and a couple of friends are doing a 9th grade science project and we want to know, were to get information on this question "Do coins rust faster in saltwater or freshwater?" we need as much help as possible this is counted for 5 grades and we need help!
Desera M ![]()
Student - Dallas Tx United States
+++++++ Here are the two different approaches you could take, Desera: 1. Do the research first or The first unfortunately can lead to "junk science" (deciding what you want the result to be, then doing the experiment again and again, as wacky as necessary until it finally comes out the way you were led to expect. Then you cross your fingers and hope it would come out the same way next time.) The second approach is, I think, a better route to 'the scientific method' for school kids who will find themselves very tempted to "fix" their observations so things come out the way they think it's supposed to. Please tell us the results you got and we'll try to help you explain them. Good luck.
I am conducting an expirement concerning the rate of corrosion
versus the amount of salt in water. I did my research and concluded
that metal should rust faster in relation to the salt content of the
water. However, the opposite is true. I have several jars set up. the
first being pure distilled water, then a series with 2 tsp, 4 tsp,
and 8 tsp of salt in 4 oz of water. While trying to answer why my
experiment came out opposite of what I thought, I found several
confusing answers all written for more advanced students. Can someone
offer an easy to understand reason. I am going to give my experiment
two more days, then repeat it to see if it comes out the same.
Courtney
5th grade
Courtney J ![]()
- Fort Bliss, Texas
Your results are your results, Courtney; if they do not support the theory that more salt leads to faster rusting, that's fine.
Science is based on experiment, not consensus! If you read that "The majority of scientists believe . . .", what that really means is everyone is still just guessing.
But I think that once you have 2 tsp of salt in 4 ounces of water, it's plenty salty. I would not expect more salt to have any effect. In fact, when you see any salt "sludge" in the bottom of your bowl, you've passed the "solubility limit" and any extra salt isn't dissolving anyway.
If you were in high school and the laboratory had an analytical balance (a very precise scale), you might be able to weigh the metal after immersion to determine which piece had the greatest weight loss, but just going by eye on the amount of rusting, my results were the same as yours. It is true that salt water is more corrosive than fresh water, but the experiment apparently needs to be conducted differently to prove it, and I don't know how a 5th-grader can prove it. I'd suggest that when the test is done you rub all the rust off the metal onto the inside of a coffee filter, then pour the remaining water through the coffee filter and display these rusty coffee filters as your evidence of which solution caused the most rusting. Good luck.
I'm doing a science experiment for 6th grade and I'm trying to
figure out the corrosive effects of fresh versus salt water over time
on various steel surfaces, from untreated, to brass plated, zinc
plated, painted, etc, to see what happens to such common building
materials with exposure to elements over time.
So far, my results completely contradict the information I've read in
books. My materials are completely under either fresh or salt water
kept at a constant temperature. I didn't use a cover. They are
exposed to air, like regular building materials would be. They seem
to be corroding at the same rate yet I know that's not
possible.
Can someone please give me some advice on what I'm doing wrong?
Francesca L ![]()
Student - New York, NY
February 25, 2008 Please help me find which coin will corrode faster in fresh or salt water!!!please today!!!!!!!! I have no sotuation. Jazmine S
March 9, 2008 I am in 6th grade with a science fair that counts for much of my grade. I am required to have 2 research sources (1 print based)and am wondering how to get them. My project is about corroding coins in freshwater, salt water, and chlorinated water. This is the only site I could find that really helps me. Please post your response soon. Thanks! Ray B.
December 7, 2008 Just in case anybody was doing an experiment and wasn't
getting accurate results, here is the scientific method
(sort of an outline for your experiment): Lingshon Mai
Save
This Page (why?) - Home - ©1995-2009 finishing.com
