finishing.com logo ips1
HOME FAQs BOOKS JOBS: Help Wanted Suggestions      you are here: Hotline/Forum => Letter 10347
Boron treatment
I needto know more about boron removal. Please asisist me . Is there any polymer that can treat the boron. Please provide me the P&ID; for the process if there is any.
Mohd H. [last name deleted for privacy by Editor]
Engineered Management System - Malaysia
Boron can be tricky to remove, especially if you do not know what form it is in. It can be as boron, as boric acid, as borate, or many others. There are several methods to remove boron from waste water, and given your location, I would say that you are likely getting hit with Maylasia B standards, right? If thats the case, then you should look at a capture, concentrate, and haul technology that will get you to the very low standards reliably. I am not aware of any polymers that have successfully been implemented to remove boron. There are specific ion exchange resins that we have used to remove it, and they fair well as long as they are taken care of and the pre-treatment is completed correctly.
Tom Baker
      wastewater treatment specialist
Warminster, Pennsylvania
Ed. note: We have lost contact
with Tom. If anyone has contact
info, please advise.
Majority of what you see will be borate ions. Try contacting your local Rohm & Haas ion exchange resin dealer and ask for XE-243 or it's latest equivalent. You can also use a product from Purolite, S-108. These resins regenerate with sulfuric acid and allow you to crystallize boric acid in hig acid concentrations, so no haul off is necessary, and the boric acid can be reused in the process wher eit came from. Hope this helps.
Juzer Jangbarwala
wastewater treatment supplier - Santa fe Springs, CA-USA
I would not recommend the reuse of boric acid obtained from regenerated ion exchange resin. While it is certainly a novel method of removing borate, the purity of the boric acid is so low as compared to even a moderate purity of technical grade boric acid that you would be looking for trouble in your plating quality. Same goes for metals and metal solutions - they don't even meet the most liberal purity standards required by platers.
The regeneration is a two step process, and requires sodium hydroxide to condition the resin to accept borate. If you want to pursue that method, be prepared to have an extra waste stream to treat that is essentially just another cost center.
Tom Baker
Ed. note: Readers who wish to answer, please do so. Readers who are looking for answers please see our FAQ on waste water treatments for boron. It lists the more than 20 threads on this topic that are on line here.
