HOME FAQs BOOKS JOBS: Help Wanted Suggestions you are here: Hotline/Forum => Letter 10156
D.I. Water and Anodized Aluminim Compatibility
Will simple anodized aluminum be compatible for use with deionized water? If not, what would protect the best?
Ronald Adolphhydraulic filters - Sturtevant, Wisconsin
If aluminum is the material of your choice, "anodized aluminum" is the best for use in DI water. Chlorine in water is not good for anodic oxide film.
Timur Ulucakaluminum extrusions & finishing - Istanbul, Turkey
You also need to seal the same to become totally resistant to the water as well.
H.KHATAU- Bombay, INDIA
