finishing.com logo ips1
HOME FAQs BOOKS JOBS: Help Wanted Suggestions      you are here: Hotline/Forum => Letter 10074
What finish for non-magnetic steel tubing?
Hello,
I am searching for non-magnetic steel tubing about 2-3 millimeters in diameter. I was thinking of nickel chromium. I am unsure of what type of finish would be best.
Any suggestions?
Dan Mac
- Boston, Massachusetts
We have no idea what this tube is being used for. Have you considered stainless steel or PVC?
Tim Neveau
Rochester Hills, Michigan
First of three simultaneous responses --
If you're unsure of what finish to specify, Dan, how do you think WE feel when we have not the slightest idea of the application or environment?  :-)
Please flesh it out a bit for us :-)
finishing.com
Brick, New Jersey
Second of three simultaneous responses --
All of the grades in the AISI 300 series are nonmagnetic. There is a wide variety of mechanical properties and corrosion resistance in the series. The simplest and most readily available are 304, 304L, 316, 316L and 321. If your main requirement is nonmagnetic and you aren't worried about corrosion resistance aspects, 304 or 316 would be the way to go. The AISI series designation is used right around the world, so any supplier worth dealing with will know it.
Bill Reynolds
   consultant metallurgist
Ballarat, Victoria, Australia
It is this website's profoundly sad
duty to relate the news that Bill
passed away on Jan. 29, 2010.
Third of three simultaneous responses --
Hello Dan!
If you go with a 300 series stainless steel (304, 316, 321, etc) make sure that it is annealed. Cold working, even the small amount used in cold finishing to get tight tolerances, can give a bit of residual ferromagnetism. The best type of finish will depend on your application, won't it? It will also likely depend on what is available, which will change depending on the amount you plan to buy.
Lee Gearhart
metallurgist
East Aurora, New York
