finishing.com logo ips1
HOME FAQs BOOKS JOBS: Help Wanted Suggestions      you are here: Hotline/Forum => Letter 10063
Black oxidation develops on white gold
When I work out white gold jewelry pieces I get that blackish oxidation on the worked out items. I have tried to dip the pieces when hot in diluted Sulphuric acid, but the work seem not to whiten out easily, and that blackish sooty colour often remains on certain parts. What is the best whitening solution can I use to have the worked out items clean and free from basic oxides?
Joseph T
- MALTA
You need to protect the surface of your jewelry from oxidation before you heat it. Make a solution of fine Boric Acid Powder [linked by editor to product info at Amazon] and alcohol to dip your jewelry, let dry and this will create a protective film which your diluted acid will dissolve after your soldering operation.
Neil Bell
Red Sky Plating
Albuquerque, New Mexico
