NaCN Abnormality in Brass Plating
Solution
Letter 10051
I have a problem with our Brass Plating Solution. There is
abnormal consumption of NaCN even without production (i.e. 12 g/l to
10.5 g/l). At first, I thought we had wrong chemical analysis but I
was proven wrong since analyses of the other components are correct.
Some say that the NaCN reacts with the Brass Anode; some say
formation of oxides on the Anode. I would like to solicit technical
help from everyone. By the way, the Brass solution is used to plate
copper foils running at 26.5 m/min.
Ferdinand U. Collado
- Sta. Rosa, Laguna, Philippines
Is there a possibility that you are dragging in acid (which kills
the cyanide) from your pretreatment?
Joel Tomasetti
- Petersburg, Virginia
Thanks Joel for taking interest in my query. But we have several
Pure water rinses after the acid dip prior to Brass Plating.
- Sta. Rosa , Laguna, Philippines
Ferdinand,
I have been servicing and analyzing brass plating solutions for
over 30 years. There are many possible reasons for high use of
cyanide salts. Firstly, is the cyanide being broken down into sodium
carbonate (analytical procedure available in many reference books)?
If so, check the solution temperature and agitation. Either can
accelerate the breakdown of the free sodium cyanide to form sodium
carbonate and hydrogen gas. Another source of this problem is
operation at high current densities where large amounts of hydrogen
are evolved at the anode.
Gene Packman
Gene,
I think you have some points. First, we circulate the 9.5 cu.
meter brass solution constantly even without operation. We also
maintain the solution temperature at 77 degrees C. We also use high
current at 7.7 A/dm2 because of the continuous plating nature of
Copper Foil. Thanks a lot and we will consider your inputs in our
discussions.
Gene,
I understand that you have a lot of experience with brass. I have
difficulties analysing the free cyanide in brass. Do you have an
analysis process that is really working? If positive I will
appreciate of you could publish it. (the method mentioned in the
Metal Finishing guide works only for
new solution).
Sara
Michaeli
chemical process supplier
Israel
Hi Sara,
Langford and Parker, Analysis
of Electroplating and Related Solutions , say 10 ml sample,
150 ml water and 2 ml of 10% KI. Titrate slowly to prevent premature
end point. I believe that I used to titrate without the KI until the
first turbidity, only then adding the KI. I don't remember if it was
for cyanide analysis, but maybe it will improve reproducibility.
I don't remember having trouble with the analysis. What problems
are you having?
The temperature seems a bit high on the tank this would cause the
cyanide to break down quicker than may be expected.
Is it possible to turn off the heating when not in use and then
turn on in time for the tank to be ready for production?
Martin Trigg
surface treatment shop - Stroud, Glos, England
Hi Tom,
Thanks for your reply.
My problem with the cyanide is not with the end point (which is
clear), the point is that when you add a known amount of cyanide to
the tested solution and you titrate it again, you find out that the
result is not accurate.
Sara
Michaeli
Israel
Sara,
I think cyanide analysis is always free cyanide, so if you add
cyanide and make a analysis I expect that the results are lower than
the value you added. This is because of the cyanide forming
complexes. If you use always the exact same analysis method you
should get values that are usable in the control of your bathes.
Marcus Hahn
- Sachseln, Switzerland
